| My Arm is Sore... Inside Look at a SL6 Head https://slantsix.org/forum/viewtopic.php?t=38622 |
Page 3 of 3 |
| Author: | /6 Matt [ Wed Jan 20, 2010 3:59 am ] |
Quote: This view of "inside the SL6 head" helps me visualize how the upper and lower water jacket cores were done (by the factory) and how they could be layed-out in an after-market head. DD |
| Author: | sandy in BC [ Wed Jan 20, 2010 7:36 am ] |
Our local high school (165 students) offers an Art Metal 12 class that involves casting aluminum. They use a propane setup. My daughter (she is now a ticketed welder) loved the process and was allowed to pour whenver she had a mould. Most students make a shifter nob , ashh tray , death metal shrine, pipe stand or a mess. Kate got into fantasy figurines, four pound dragons etc. Tim:you should drop by sometime so Kate can take you up to the school.... Anyone interested in casting art should out Fredrick Remington. I was thinking it would be fun to port Dougs 2 piece head .....deck the two pieces for reassembly ......glue and clamp. I bet porting is more fun in a 2 piece head. Then you try it in plywood. Glue and clamp... Keep posting pictures Doug. |
| Author: | Doc [ Wed Jan 20, 2010 9:09 am ] |
Quote: Quote: This view of "inside the SL6 head" helps me visualize how the upper and lower water jacket cores were done (by the factory) and how they could be layed-out in an after-market head. DD I have "run the numbers" twice... got quotes for castings, machining, (including programming, holding fixtures, cutters & taps) and the final "press work". (installation for 12 guides and 12 valve seats) When all is said and done, we always find the same answer, "too expensive". So... I always know what "next steps" are needed for the project and time can be your friend. This year, I was able to move a few steps forward... finding someone with a big saw was one of those forward steps. There are still many more to go. DD
| Author: | SlantSixDan [ Wed Jan 20, 2010 9:43 am ] |
Now that's an interesting print. What is #3698446, and who is BW? |
| Author: | Tim Keith [ Wed Jan 20, 2010 10:55 am ] |
You can do a prototype head from steel weldments. Years ago Crosley brazed the block for its tiny Hot Shot motors. http://crosleyautoclub.com/Mighty_Tin.html There were warranty and corrosion problems, they went to an iron casting, but the thing did work. With the improved welding of today a welded prototype can work for a one off. With CNC you could fabricate and weld up a few test heads. |
| Author: | carsrme [ Wed Jan 20, 2010 2:25 pm ] |
Quote: Now that's an interesting print. What is #3698446, and who is BW?
Unless you have a better Idea, I think it might be:"Bill Weertman, the Chrysler chief engineer who worked with the Slant 6 development program from 1958 to 1987 ."( c & p from the Articles section.) Anyone got any better idea/theory ? cheers,CRM |
| Author: | sandy in BC [ Wed Jan 20, 2010 2:43 pm ] |
#3698446,........part # for the alloy head....an online check says there are 5 in Edmonton...but only 3 are the big valve version. |
| Author: | /6 Matt [ Thu Jan 21, 2010 3:31 am ] |
Quote: Quote: Quote: This view of "inside the SL6 head" helps me visualize how the upper and lower water jacket cores were done (by the factory) and how they could be layed-out in an after-market head. DD I have "run the numbers" twice... got quotes for castings, machining, (including programming, holding fixtures, cutters & taps) and the final "press work". (installation for 12 guides and 12 valve seats) When all is said and done, we always find the same answer, "too expensive". So... I always know what "next steps" are needed for the project and time can be your friend. This year, I was able to move a few steps forward... finding someone with a big saw was one of those forward steps. There are still many more to go. DD ![]() |
| Author: | SlantSixDan [ Thu Jan 21, 2010 8:26 am ] |
I thought about "BW" meaning "Bill Weertman", but I'm pretty sure he signed most of his work "Willem", not "Bill". |
| Author: | wvenable [ Thu Jan 21, 2010 4:31 pm ] |
Thanks Doc! Baby steps are still steps in the right direction! |
| Page 3 of 3 | All times are UTC-07:00 |
