| Triple one barrel setup? https://slantsix.org/forum/viewtopic.php?t=38764 |
Page 3 of 4 |
| Author: | /6 Matt [ Wed Jan 27, 2010 5:55 pm ] |
I finally got a scale picture, here is a link to the picture on facebook. http://www.facebook.com/album.php?aid=1 ... 0072781594 |
| Author: | adiffrentcity [ Wed Jan 27, 2010 6:08 pm ] |
Try posting that with Img code. I don't facebook so I can't see your drawing |
| Author: | /6 Matt [ Wed Jan 27, 2010 6:20 pm ] |
| Author: | /6 Matt [ Wed Jan 27, 2010 6:22 pm ] |
Quote: |
| Author: | adiffrentcity [ Wed Jan 27, 2010 6:31 pm ] |
Your code looks just fine. It's probably just facebook. Try using something everyone else wouldn't have to log into. Uuuuuhhhh whatsit called...... hmmmm...... not shutterfly or snapfish...... crud. Search through the "Using the site" forum for Ideas. Too close to my bedtime. Can't remember that photo-hosting site for the life of me... |
| Author: | linda [ Wed Jan 27, 2010 6:33 pm ] |
| Post subject: | Photo Hosting |
Try using something like photobucket for hosting the photos. I think that is the one that ceej uses. Linda |
| Author: | /6 Matt [ Wed Jan 27, 2010 6:33 pm ] |
shoot me neither........................ photo something???..... no, wait..... It's getting close to my bedtime too. |
| Author: | /6 Matt [ Wed Jan 27, 2010 6:36 pm ] |
here goes... drum roll please... ![]() The top picture is a black and white copy of the one barrel intake that Karasik87 posted, I used it for guidance. Picture is a 1:1 scale with the measurements from the intake on my dart. It would have been easier if I could've unbolted it and traced it. |
| Author: | /6 Matt [ Wed Jan 27, 2010 6:37 pm ] |
| Author: | adiffrentcity [ Wed Jan 27, 2010 6:52 pm ] |
Photobucket! Thank you linda! I think that would work good, your primary carb location looks identical to the stock one, and the other two are placed to feed the other cylinders when they come on. Plenum shape might not end up as pretty as you have it, but that won't be a big deal as long as the floor doesn't cause puddling. Go for it! Sweeet lookin car too. |
| Author: | GTS225 [ Wed Jan 27, 2010 6:54 pm ] |
Looks like it's going to be a little "tight" around those carbs. Remember, you have to arrange a linkage setup, throttle connection, trans kickdown (if auto trans), fuel connections and air filter(s). Keep in mind also, that one usually runs three carbs in a progressive linkage fashion. Two carbs could be run together, but three is typically progressive. Roger |
| Author: | /6 Matt [ Wed Jan 27, 2010 7:09 pm ] |
Quote: Looks like it's going to be a little "tight" around those carbs. Remember, you have to arrange a linkage setup, throttle connection, trans kickdown (if auto trans), fuel connections and air filter(s).
i'm not exactly sure what a progressive linkage is (I should know that though Keep in mind also, that one usually runs three carbs in a progressive linkage fashion. Two carbs could be run together, but three is typically progressive. Roger |
| Author: | /6 Matt [ Wed Jan 27, 2010 7:13 pm ] |
Sweeet lookin car.
Thanks, I drive it to school/work everyday and it makes me a chick magnet (and unfortunatley a guy magnet too *EDIT: actually the wheels don't look too bad on this side of the car, here's a shot of the rear though. check out the high tech custom anti theft trunk lid device ![]() and another ![]() and two more of the front, taken earlier. ![]()
| Author: | Karasik87 [ Wed Jan 27, 2010 9:28 pm ] |
That's a sweet drawing. Definitely on the right track. Do you have at least one carb laying around? My next step would be to lay a carb on a throttle bore, to see how much room the carb takes up. You'll need room for linkages, which has been mentioned. 1920's don't line up like the holley six pack carbs on the v8s |
| Author: | RustyRamcharger [ Wed Jan 27, 2010 9:34 pm ] |
PM sent to DartMan. Ken |
| Page 3 of 4 | All times are UTC-07:00 |
