Is it the choke, the carb or combo of both?
https://slantsix.org/forum/viewtopic.php?t=41312
Page 3 of 3
Author:  Joshie225 [ Sun Aug 08, 2010 11:45 pm ]
In addition to what Joey wrote...
Did a compression test with pretty dismal results. I'm really surprised it runs and idles as well as it does. Hooking up compressed air to #1 made for a good breeze out the exhaust.
Put the distributor in the distributor machine. It seemed to work pretty well with decent cylinder-to-cylinder phasing (for points), a fair advance curve and a working vacuum advance. In went new points and condenser. It's really quite nice to be able to set the dwell with the distributor spinning. :-)
Put the distributor back in the engine and couldn't get enough initial timing so it came back out so I could adjust the hold-down plate. Got the initial timing at 5 degrees BTDC.
Had a successful test drive.
Also, I have a 10" drum hub to which you're welcome if you don't mind the tack-welded wheel studs.
Author:  SwingerGrrl73 [ Mon Aug 09, 2010 11:24 am ]
Ah, yes. The compression test. Yeah, that was pretty bad!
Somewhere I have the numbers from when Neil did the first test when I got her. I need to find them and compare!
I may need to get a ride up there Josh, but if you want to let that go I will take it!
Page 3 of 3 All times are UTC-07:00
