Turbo 74 Duster
https://slantsix.org/forum/viewtopic.php?t=42393
Page 3 of 13
Author:  1974duster kev [ Mon Nov 29, 2010 9:23 pm ]
I've been lazy lately homework has been kicking my ass in statistics and oceanography what an easy subject to learn about oceans yet everything i study doesn't appear to be on any of the tests :cry:
I filed the rings crank is tqed in along with pistons and rods just gotta button up some things before finishing the bolt on stuff
Oh checked vlave clearance had miles of room 8.5:1 compression
Found a trunk mounted 1.5gal meth kit anybody seen it? it's on ebay debating if i should buy it any suggestions?
Kev
Author:  1974duster kev [ Mon Nov 29, 2010 10:01 pm ]
http://cgi.ebay.com/ebaymotors/water-me ... 19c10c2b31
Should i buy it does it look sketching like ebay crap??
Kev
Author:  Sam Powell [ Sun Dec 05, 2010 6:34 am ]
It looks similar to the DEvils Own kit a bought for $300. I like the idea of putting the unit in the trunk. I may see if I can fit the water bottle only there. It just has to sit above the pump (ideally) and right now my pump is down low in from of the front wheel.
I might want to spend another $100 and get the devils own, which has a control box to set the boost rate it comes on at, and how much flow there is. A lot of the hardware looks similar though.
Sam
Author:  Sam Powell [ Sun Dec 05, 2010 6:45 am ]
I had a similar problem on a turbo Chevy 6 and cured the problem with more ignition timing and a pressure retard indexed to the intake. MUCH better economy, too.
Explain more here please.
Sam
Author:  1974duster kev [ Fri Jan 07, 2011 11:43 am ]
Ok the engine is built on the stand, yanking my motor tonight, time to start hooking the turbo stuff up :twisted:
Ya i'll probably buy that trunk mount kit its my daily driver so it's gonna get beat on and i'd hate to constantly be refilling those little jugs how long does your jug of meth last? i'm thinking the trunk mount 1.5gallon would last alot of wot pulls.
Kev
Author:  turbo66valiant [ Sun Jan 09, 2011 8:57 pm ]
Kev
Your 1.5 gln will last a long time. Mine is a 1/2 gallon and drops about 1/8 " to 1/4" on each run. It also has the 14 gph jet in it. Later
Author:  1974duster kev [ Sat Jan 22, 2011 6:43 pm ]
Sweeeet thats what i was hoping since this is my daily driver I didn't wanna have to refill that tank everyday.
Ok update, Motor is in trans is in, header to the turbo done and mounted, turbo (kinda done need a silcone connector)to intercooler back to motor done and mounted.
To do list-
run new fuel lines for elec pump from tank to carb and mount regulator
finish wastegate piping and downpipe
hook up boost gauge, temp gauge, A/F gauge
weld in subframe connectors
I'm sure some more stuff i'm forgetting about
OH can i start and drive the car? with the turbo not piped into the intercooler if i can't get the part i need by tommorow?
Kev
Author:  Shaker223 [ Sun Jan 23, 2011 8:41 am ]
Kev
I wouldn't. I've heard of over-reving the turbo. Not sure if it is true or not.
Author:  1974duster kev [ Sun Jan 23, 2011 1:16 pm ]
Thats exactly what i was thinking ok i won't drive it looks like i'm waiting on one dam little silicone adapter :(
Kev
Author:  1974duster kev [ Wed Jan 26, 2011 6:10 pm ]
Riddle me this, in theory a turbo spools more or less from the load on the motor because of the heat not so much the exhaust speed. So in theory if I wrapped my headers with header wrap to keep the heat in, my turbo would perform better or spool quicker right? Has anyone found any evidence of this being true or actually working, or would it be a very small change and thus not noticeable?
Kev
Author:  Shaker223 [ Wed Jan 26, 2011 7:01 pm ]
It spools from both actually. A wrap will help two ways. Keep temps and radiant heat down and help with a little faster spool.
Author:  1974duster kev [ Thu Jan 27, 2011 8:02 pm ]
Update- down pipe is done all the way back to the axle, only thing left is run fuel lines and vac lines.
Gonna try and start the animal tommorow after work!! :!: :D
Kev
Author:  turbo66valiant [ Fri Jan 28, 2011 12:16 pm ]
PICS??
Author:  1974duster kev [ Fri Jan 28, 2011 6:02 pm ]
Author:  1974duster kev [ Fri Jan 28, 2011 6:09 pm ]
Page 3 of 13 All times are UTC-07:00
