It is currently Mon Sep 21, 2026 11:45 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Dec 26, 2010 11:00 am
Hi WhaleMstr, here are my 2 cent's worth of nogoodadvice... 8)
I tried opening the needle valves( idle mixture screws?) up a turn each - no go - tried 1.5 turns - no go - guess I should try 2+ next
Some of these carbs have 'reverse' metering plates, so the needles control only the air for the idle mixture; i.e. turning them outwards actually leans out the mixture instead of enrichening it.
I cannot see if you have used this spesific carb size before, but it is a big carb, and giving the power valves a faulty vacuum signal will play havoc on the setup, I don't know this carb in detail, but can you possibly check the power valve circuit for leaks?
Do you have a vacuum gauge to see where your power valves open (or not)?
These kind of troubles can be hell to diagnose, good luck.
Olaf.
Aspenized
Users browsing this forum: DuckDuckGo [Bot] and 14 guests
