It is currently Sat Nov 28, 2026 2:25 pm
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Sat Jul 09, 2011 9:04 pm
pin shaft is just that loose, I have just kinda assembled it on the table 4photos. I posted a wanted reverse manual valve body w/trans brake on big block darts forum as I posted a build our other 1968 calif no rust dodge dart 2+ years ago and ran out of $$$ for that. so I bought this slant six car also to cut my teeth.
anyhow got it from bOb @ a real good price. he said he had it on his race car back in the day. he also builds valve bodies and sells them on big block dart forum.
just ordered a billet spacer for the filter on ebay..$30 delivered w/orings/screws.
now I need a deep pan. would like to pull one from a pick/pay Sunday but do not know what model trucks have a A500 trans..the pan should be deep and work..I think
no written instructions but bOb told me how it works.
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Feb 06, 2012 10:55 am
we bought a 7.25 rebuilt sure-grip rear and spare
has the good posi
and some 5.38's NOS gears
now have to install an OD trans
looks like auto and T5 aprox same cost
when built out.
slant six's RULE!
 Post subject: Mason Dixon
PostPosted: Mon Feb 06, 2012 1:02 pm
You better have that thing ready by may!! :D :D Expect to see you at Mason Dixon
Rick
PostPosted: Mon Feb 06, 2012 1:27 pm
Be careful with the overdrive ratio you select. If you need 5th gear on the track it needs to be close ratio otherwise the car will fall on it's face at the big end of the track. The 5th gear in most V8 T5s is way too steep. You want something in the .85-.88 range.
PostPosted: Mon Feb 06, 2012 1:38 pm
what not just use 4 gears in the 1/4 mile with the V8 trans gearing 5th= .68
I not sure if I understand this
our car is not just for racing it is stock heavy
the motor is stock
just headers
this is ford ID chart
http://www.allfordmustangs.com/Detailed/349.shtml
RPM calculator
http://www.csgnetwork.com/multirpmcalc.html
slant six's RULE!
PostPosted: Mon Feb 06, 2012 2:04 pm
I don't think you have a tall enough tire or enough RPM to run 5.38s in direct on the strip.
PostPosted: Mon Feb 06, 2012 2:43 pm
30 inch rear tire
slant six's RULE!
PostPosted: Fri Jul 12, 2013 5:56 pm
Dart is in the back yard/next to and engine on a stand/next to an engine crane...need to pull early slant and glue the late slant to our tranz act trans build to late slant..then reassemble exhaust/wires/driveshaft..stuff.
slant six's RULE!
PostPosted: Mon Jul 15, 2013 5:21 am
Uploaded with ImageShack.us
slant six's RULE!
PostPosted: Wed Jul 17, 2013 7:12 am
Hope to see you at a race later this year!
PostPosted: Wed Jul 24, 2013 8:44 pm
that b nice. just to tool around local would be nice too.
slant six's RULE!
 Post subject: july 26, 2013
PostPosted: Fri Jul 26, 2013 6:20 pm
made a homemade transmission mount for floor jack 2day after trying to use the reg jack for 4 hours yesterday and getting no where. installed trans ..slowly but slantly...
we r in da dirt .
slant six's RULE!
PostPosted: Fri Aug 09, 2013 6:55 pm
thought I would install trans cooler/filter b4 installing headers..
slant six's RULE!
PostPosted: Fri Aug 09, 2013 7:11 pm
Jon,
If you are working on uneven ground under the
car, in dirt / gravel whatever, a 4x8 sheet of plywood is invaluable for your floor jack or engine crane.. should be easy to put that stuff in then.
When not in use you can store it against the wall or on the floor in a shed , basement, garage and it's ready to go anytime you do your next dirt install.
PostPosted: Fri Aug 09, 2013 7:13 pm
oops, I see you had a sheet under there.
get er done!
