64 A100. What Auto Tranny?
https://slantsix.org/forum/viewtopic.php?t=45172
Page 3 of 3
Author:  greasmnky [ Fri Apr 15, 2022 9:51 am ]
Post subject:  Re: 64 A100. What Auto Tranny?
Is your 833 in your A100 a four speed plus overdrive? Or is fourth gear OD? Also, column shift?
yes I use a full length 833 OD transmission . use a B van transmission mount , have to drill a couple hole .I have done both floor and column shift . for the floor shift I made a mount , full frame width , bolted to the stabilizer frame mounts .The column shift ended up with a W pattern instead of the traditional H , worked great . Now comes the fun part, there is no provision for reverse once you have used the 4 column shift positions .I found a short shifter ,mine came from a Toyota transfer case , has a 4 mounting hole base and bolted it to the floor , weld an extension on the bottom to be able to mount the shifting rod from the reverse transmission arm . The bonus is that you can put the transmission in 3rd or OD and engage the small shifter in reverse , locking the transmission in 2 gears giving you an awesome park brake .
Page 3 of 3 All times are UTC-08:00
