It is currently Tue Nov 24, 2026 11:44 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Aug 30, 2012 4:52 am
i started with 15deg then hook the vac pod up and had to tighten the spring load alot to get it to stay at 25 degs when i throttle up the engine to increase manifold vac level. i only have 5bls vac at idle and 18bls on decleration,that under load . when i started increacing my intitial timing i never checked the vac adj timing but it should be 30deg if everything stayed the same. i only pick the 25deg because that was the most my high comp engine would handle with out hurting the top piston ring.
PostPosted: Mon Jan 21, 2013 5:09 pm
Slantscamp do you have a pic of blower and or carb with hood closed?? Thanks
1963 Plymouth Valiant Wagon
PostPosted: Fri Jan 25, 2013 8:51 pm
Dang that there is sweet !!!
Dennis
PostPosted: Mon Jan 28, 2013 6:18 pm
well i know its been a while guys. i guess i got a little burned out on my car. work and school have been really busy. here are a few pictures though. one is of my car at a local show. and the others are of my hood i put on sunday. i need to clean up some of the cuts, but i just wanted to get the hood back on the car to free up some room in the garage.
Image[/img]
it's not only good. it's good enough.
PostPosted: Mon Jan 28, 2013 6:38 pm
oh yeah, i forgot another update. i finally tapered the opening in the adapter, and redesigned it a bit. i was worried about the blower gasket leaking because the sealing surface of the blower ran right over the countersunk bolt that holds the plate to the intake. what i came up with is a second piece with a custom gasket that seals to the bottom plate and gives the blower a nice unobstructed metal surface to seal to. i also had a local machine shop surface both pieces to make sure they were flat. i know this thing is thick, but it came in handy when i tapered the opening, and i didnt want to worry about the top plate warping, so i went a little on the thick side. im not trying to make this car super fast, im just trying to have fun with it, and make people look twice. so far its been working haha.
PostPosted: Tue Jan 29, 2013 4:49 am
nice job on the intake and adaptor . i had the same setup and i just put some black rtv on the tappered screw heads with no problems at 12psi of boost.
PostPosted: Tue Jan 29, 2013 5:42 am
Looks great! How many people ask if it's got a hemi before you open the hood?
PostPosted: Fri Feb 01, 2013 5:17 pm
Thanks guys. That rtv trick is good to know. I thought about that but wasnt sure if it would work. I have only taken the wagon out twice and it didn't have a hood. But it sure did draw a crowd.
PostPosted: Mon Feb 18, 2013 9:43 pm
Man that is pretty freaking awesome !!!! On the RTV I would use the grey in the caulk gun tube available at most autopart stores, same stuff as the MOPAR grey RTV, and it seals everything, and is oil resistant, fuel eh as long as you don't soak it in gas your good to go lol
-Mike
I am the Guardian, I hate helos, everything leaks.......
