| Factory carb heatshield pictures https://slantsix.org/forum/viewtopic.php?t=46314 |
Page 3 of 6 |
| Author: | Rug_Trucker [ Thu Sep 06, 2012 4:39 pm ] |
Ramchargers were from the 80's. The vehicle I saw it in was a state of Tennessee vehicle. 4X2. |
| Author: | Bruce Pine [ Thu Sep 06, 2012 5:07 pm ] |
Just got home from PicknPull in Chico. 77 Aspen had factory heat shield, with a fresh carb for my 77 Aspen. I snagged them both. The heat shield can go to whoever will do the right thing with it. Let me know. Bruce |
| Author: | SlantSixDan [ Thu Sep 06, 2012 6:45 pm ] |
If nobody else steps up with intent and means to create a pattern for the heat shield, I'll do it. |
| Author: | Reed [ Thu Sep 06, 2012 8:01 pm ] |
I would say I would do it, but it would be a lie. I know it would end up shoved off to one side of my workbench next to a pencil and a pad of graph paper and I would keep meaning to do something with it but would never find the time.... |
| Author: | enrique lopez [ Thu Sep 06, 2012 8:44 pm ] |
I have one at home. I could trace it and send it in, problem is, I dont have a scaner big enough... |
| Author: | Nomad [ Thu Sep 06, 2012 10:15 pm ] |
Quote: The heat shield can go to whoever will do the right thing with it. Well, I can create a vector file of it and make it available for download, so if shipping it to Canada is not too high, I'm interested.Quote: If nobody else steps up with intent and means to create a pattern for the heat shield, I'll do it. Dan, with your knowledge you might do a better job than me (like maybe creating a 2 barrel version like Reed suggested). What do you think?Quote: I have one at home. I could trace it and send it in, problem is, I dont have a scaner big enough... You can try scanning it in parts, with enough overlapping and some registration marks, I should be able to trace a full size template.(Laying a ruler on the scanner for reference will also help). Good friend of mine is building a CNC machine. I hope he will be willing to cut a few shields out of an aluminum plate. |
| Author: | 62 alum [ Thu Sep 06, 2012 11:44 pm ] |
I have the factory two piece type off a 1981 truck. I also have made one for a two bbl carb that seems to work well. I do not have the means to copy or fax these but I would be willing to mail them to some one that can copy them. The down side is I would like them back. |
| Author: | Jeb [ Fri Sep 07, 2012 12:51 am ] |
Send your heatshield to Agressive Ted. The one I had seems to have disappeared. |
| Author: | Josh P [ Fri Sep 07, 2012 8:54 am ] |
Not to get side tracked, but were there ever a heat shield for the Super Six, or would it be of much benefit? Also to toss this out there, I have a friend with a couple CNC machines, so maybe he'd be interested in doing a small run as well. |
| Author: | SlantSixDan [ Fri Sep 07, 2012 9:38 am ] |
"Need them back" is not an impediment as far as I'm concerned. 2bbl version is yes. |
| Author: | MLC Duster [ Fri Sep 07, 2012 11:35 am ] |
I made a full size pdf of a template created from the photos. I'd gladly post it here if someone would tell me how. Don't know how to post a pdf. |
| Author: | MLC Duster [ Fri Sep 07, 2012 11:43 am ] |
Here are photos of my crude template and pdf printout of same. If you want a copy of the pdf, let me know, I'll be glad to email. ![]()
| Author: | Josh P [ Fri Sep 07, 2012 12:51 pm ] |
Quote: 2bbl version is yes.
Is that to say that there was a factory heat shield for 2bbl slant sixes? Do you have a picture of one or can describe how they vary from the 1bbl shields?
| Author: | Aggressive Ted [ Fri Sep 07, 2012 2:44 pm ] |
| Post subject: | Heat shield |
MLC Duster, PM sent with address. Thanks, |
| Author: | MLC Duster [ Fri Sep 07, 2012 3:59 pm ] |
Guys, I need an email address if you want a copy of the template. It is in pdf format. Or, better yet, if a moderator could post it for anyway to get--that would be more efficient. |
| Page 3 of 6 | All times are UTC-08:00 |
