It is currently Sat Nov 28, 2026 4:33 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Wed Jan 11, 2012 6:27 pm
So I take it, you don't see a great advantage to larger valves on a daily driven slant?
I have nothing to compare it to. I wanted bigger valves in my Duster. I dropped $400 into the machine work. The machinist suggested Chevy valves but wasn't sure. I didn't have the time and funds to go bigger.
For a work truck like my friends? Bigger probably would have been money spent elsewhere.
One other note on the van head. He used to have pinging on regular 87 octane. He used to run 89. He now uses 87 with no issues. We did swap over to a '77 model BBD out of his other California spec van with another 833OD.
PostPosted: Wed Jan 11, 2012 7:47 pm
6 Pack Dart
One thing to remember is the head was designed for the 170 and wasn't changed to go on the 198 or 225. The bigger motors would most likly want bigger valves and ports (be carefull when enlarging the ports).
Richard
PostPosted: Wed Jan 11, 2012 8:06 pm
Richard
Lots of people say that,and I agree that a bigger port/valve would be better for the 225...but...Stock intake flow with a stock valve is around 160'ish correct? Lets call it 150 to be on the safe side,here is a formula for determining how much HP your CFM will support:
(CFMx.25)x6= hp potential
So: (150x.25)= 37.5x6=225 hp potential. So with max VE the stock head will support 225 hp.
Check out this thread over at fabo with what my buddy found with his flowbench and a stock slant head,a ported head, and a big valve head. Pretty interesting.
http://www.forabodiesonly.com/mopar/sho ... p?t=160502
PostPosted: Thu Jan 12, 2012 12:13 am
Richard
At what lift/rpm do you see gains from the bigger valves?
Where could bigger valves hurt you? (if at all)
PostPosted: Thu Jan 12, 2012 11:11 am
6 Pack Dart
See this,
http://www.dutra.org/doug/flow/data.pdf
and you decide.
Richard
PostPosted: Thu Jan 12, 2012 12:40 pm
See this,
and you decide.
Richard
But what was done along with adding the 1.7 valves? There is no way that you gain 35 cfm at .500 from just a valve change,and blending the seat to match the big valve,see the link I posted above.That was my head,it flowed at 158 @.500 stock and only got to 166cfm with the large valves/seat blend,and after a little work by my friend justin it got to 175 cfm @ .500. Even with a back cut,you MIGHT be looking at 180 cfm.
PostPosted: Thu Jan 12, 2012 1:25 pm
6 Pack Dart
You decide what you want.
Richard
PostPosted: Thu Jan 12, 2012 4:37 pm
Is there no more info on what was done to get those numbers? Its hard for me to make an informed decision with no information,I am trying to figure this out. I do know for what I am doing with my truck,I will be keeping the stock size valves(with a back cut) and just doing a little clean up in the bowl/port areas.But its only going to have a BBD,small cam,and 8.5-9.0 compression,nothing exotic.
PostPosted: Fri Jan 13, 2012 9:06 am
In general street running if you lose velocity it would possibly make things sluggish.
Like the door on our soap stone wood burning stove. All the way open losts of sluggish air gets in to feed the fire. Turn the latch so the door hangs open 1"? Things get roaring! Lots of turbulance in there.
 Post subject: Sure be nice.
PostPosted: Fri Jan 13, 2012 4:43 pm
Car Model: 1962 Dodge Lancer GT Black/Red
I am thankful for the comments being made here. DI likes small valves too.
Would sure also be nice to get the perspectives aggressive and joshie included in this discussion. : :)
PostPosted: Sat Jan 14, 2012 6:06 am
In my experience, you lose nothing by going to bigger valves for street use on a 225. A 170 *maybe*. I have run everything from stock to 1.76/1.50 on the street, and it's all good. My '68 (before turbo, and even now at low RPMs) has a tiny MP 244 cam and maxed out Mike Jeffrey head with 1.76/1.50 valves. Makes great low end and 22-23 MPG hwy, AND pulls to 5500 RPM. 16.30s best with 8.7:1 and heavy car (3350+ racewt). Really, these valves were set up for a 3.5" bore motor, so they are not optimal for this 3.43" motor, but 1.70/1.44 are good for stock or mild overbore.
Yes, if you put in bigger valves and do not bother to do bowl work (big ridges, mostly), then you won't gain much.
Yes, if you use stock valves and do a lot of port/bowl work, then you can make it flow well. I personally have never bothered to do this, but others I know have had decent (but not huge) gains.
My 2 cents...
 Post subject: Thank you Lou.
PostPosted: Sat Jan 14, 2012 8:21 am
Thank you Lou, for your practical straight forward, rubber meets the road, experience based comments
PostPosted: Sat Jan 14, 2012 10:05 am
Lou-
Any idea what all was done to the 1.7 valve head that flows 194 cfm@.500 in that link on Dougs website?
PostPosted: Sat Jan 14, 2012 10:21 am
I put a mildly ported head with 1.70/1.44" valves on the stock short block in my '67 Valiant. The head was milled enough to raise the compression from 8.0:1 to 8.5:1. I also did intake and exhaust upgrades. I don't believe I lost any low end torque and the mid range was greatly improved. I mean 2+ seconds in the 1/4 mile improved. A cam upgrade would have cost me a slight amount of low end and improved the mid range and top end quite a bit.
If I were hard up for cash I would just use a stock '72+ mechanical cam, 1.70" intake valves, port the head, Super Six induction, shim head gasket and 2 1/4" exhaust. This would require a head with hardened exhaust seats and exhaust valves in good condition which I don't think is likely unless you have a nice later model donor head.
PostPosted: Sat Jan 14, 2012 12:46 pm
Thanks Josh, I paid PER for that this time ($900). Mostly for time's sake as this truck is used for business. Hopefully by next time I can learn to do the porting for myself. Your comments and suggestions are always welcome on my posts . . . Just saying . . Thank you
Users browsing this forum: DuckDuckGo [Bot] and 5 guests
