| Carb heat shield / insulater https://slantsix.org/forum/viewtopic.php?t=49493 |
Page 3 of 3 |
| Author: | Reed [ Sun Aug 12, 2012 5:22 pm ] |
Quote: Use a factory air cleaner with a thermostatic snorkel. An air cleaner with an open/exposed element is not better, it's worse.
+1. And rig up a true cold air intake while you are at it. No point in sucking in hot underhood air when it is so easy to rig up a cold air intake.
| Author: | Super6er [ Sun Aug 12, 2012 7:00 pm ] |
It's just temporary air cleaner for now to keep dirt out of the carb while I'm tuning and tinkering with it, I have a 10" that needs the bottom shaved down for my hood clearance. Hmm...Cold air intake is a good ideal as well. Thanks for all the feedback. |
| Author: | Aggressive Ted [ Sun Aug 12, 2012 11:18 pm ] |
Yes, a cold air take is really worth it in terms of mileage and performance. Take a look at mine.....cost is about $15 in a few common parts. You can also view my simple aluminum heat shield which really works in two important ways. Keeping the carb cool and the number 1 runner warmer. Click on the red link below my name to view pictures. |
| Author: | olafla [ Mon Aug 13, 2012 12:18 pm ] |
Hi Super6er. There are some differences in the manifold to carb insulator gasket, between different BBD versions, be sure you have the correct one. You will see them if you take a look in this manual, from page 26 -> on: Carter BBD operation and repair manual(pdf) Olaf. |
| Author: | Super6er [ Mon Aug 13, 2012 6:45 pm ] |
Very good info thanks for sharing.. |
| Page 3 of 3 | All times are UTC-07:00 |
