It is currently Sun Nov 29, 2026 7:32 am
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Sun May 25, 2014 11:46 am
Nice!!!!
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Tue Jul 01, 2014 12:16 am
small update, made a intercooler beading tool, hot rod style :)
cut out new gasket material for wastegate mount and dump pipe
finally mounted wastegate, mocked up, welded flanged end of and wrapped dump pipe
turbo exhaust pipe wrapped up
thermal blanket on and safety wired
the plate for the Mitsubishi 3000GT sending unit
the bigger gas tank was a bust, it just wasn't in the stars for me, so i ordered a new tank, going to just cut the top of the tank, weld on the plate ( after i cut it back off the failure) and sump it to fit the sending unit
with the -6 feed 90* bulkhead fitting :)
BTW normally HF has crap tools, but this tubing cutting was freaking awesome !!!!! but get the one witht the nuts and bolts not the one thats riveted !!!!!!
cut a rectangular hole in the core support for the IC piping, only got one tube through so probably gonna weld up the hole in the future, yea i know $#!+ sealant job lol
pride and joy right here, beautifully bent vent tube extensions, copper wire wrapped and soldered together !!!
shot down the hole
oh and i think i am good on the AN hoses right now got everything from -4 to -34 an :) guess it pays to raid the junk bin at work
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Tue Jul 01, 2014 3:12 am
Looking great!
