| Hardened Oil Pump Gears, They are Done! https://slantsix.org/forum/viewtopic.php?t=5240 |
Page 3 of 3 |
| Author: | emsvitil [ Thu Aug 20, 2020 7:55 pm ] |
| Post subject: | Re: Hardened Oil Pump Gears, They are Done! |
How hot can you get the gear before you have to worry about any heat treating it may have? I'm just wondering if the technique I used with my lawn mower flywheel would work. I cranked up the gear puller, then took my plumbers torch to the flywheel. After about a minute the flywheel popped loose. |
| Author: | Doctor Dodge [ Fri Aug 21, 2020 10:16 am ] |
Kinda complicated because this is dependent on the amount of carbon in the iron / steel. In general, you will not impact hardness if you stay under 1000 degrees F. See this paper for more detail: http://www.heat-treat-doctor.com/docume ... tIrons.pdf DD |
| Author: | jcc [ Thu Sep 03, 2020 8:36 pm ] |
Quote: How hot can you get the gear before you have to worry about any heat treating it may have?
I agree there is no one magic threshold temperature, but physical properties start to change I believe as the material approaches 700F.
| Page 3 of 3 | All times are UTC-08:00 |
