| ignition https://slantsix.org/forum/viewtopic.php?t=53391 |
Page 3 of 6 |
| Author: | Reed [ Wed Sep 25, 2013 2:45 pm ] |
Resistor for the choke thermostat. The wire spliced into one of the field wires from the alternator feeds current to one side of that resistor and the other side of that resistor attaches to the wire that goes to the choke thermostat bolted in the exhaust manifold. Bolt the resistor to the rear bolt hole in the top of the head.
| Author: | 1930 [ Wed Sep 25, 2013 2:46 pm ] |
Better yet maybe I would be better off getting an entire underhood harness from another 1984 truck that does not have this lean burn dist, maybe that would make my life easier and make things look neater? I do know where there is one but I do not know how much longer, it would be the same truck I removed points dist from. |
| Author: | Reed [ Wed Sep 25, 2013 2:46 pm ] |
The black one I believe plugs into part of the EGR vacuum control system. The white plug is J1C-14R on the wiring diagram I posted. It is the positive feed for the oil pressure sending unit as well as the choke thermostat.
| Author: | Reed [ Wed Sep 25, 2013 2:54 pm ] |
If you are willing to put in the time, it is very easy to unwrap the wiring harness under the hood and remove just the wires you want to remove. I did this last summer on my brother's 1983 Dodge van. It was originally built with lean burn but a previous owner hacked in a non-lean burn carb and distributor. I unwrapped the original wiring harness and removed all the unnecessary wires. It is actually pretty easy because you will find that most of the wires in the two big black plugs that went to the lean burn computer are the wires for the emissions related items that have been removed. If you follow those wires and remove only them then your harness will get much cleaner. The only tricky part is using the wiring diagram to make sure that you aren't also removing a power feed or wire for some item that you are keeping, such as the oil pressure sending unit or the choke thermostat. It isn't that hard though. |
| Author: | 1930 [ Wed Sep 25, 2013 2:55 pm ] |
Quote: Yay. If you do have the "brain" on the firewall then you don't have a lean burn controlled ignition. But verify that you don't have a lean burn controlled carb.
If I had the brain on the firewall ( which I did on both trucks ) than is this just a mistake or am I not reading it correctly?
| Author: | 1930 [ Wed Sep 25, 2013 2:56 pm ] |
Quote: If you are willing to put in the time, it is very easy to unwrap the wiring harness under the hood and remove just the wires you want to remove. I did this last summer on my brother's 1983 Dodge van. It was originally built with lean burn but a previous owner hacked in a non-lean burn carb and distributor. I unwrapped the original wiring harness and removed all the unnecessary wires. It is actually pretty easy because you will find that most of the wires in the two big black plugs that went to the lean burn computer are the wires for the emissions related items that have been removed. If you follow those wires and remove only them then your harness will get much cleaner. The only tricky part is using the wiring diagram to make sure that you aren't also removing a power feed or wire for some item that you are keeping, such as the oil pressure sending unit or the choke thermostat. It isn't that hard though.
I will most certainly do this, what do you recommend at this point that I do with my ignition ( other than the HEI ) you say I cannot or should not use either dist? Thank-you for your time |
| Author: | 1930 [ Wed Sep 25, 2013 2:57 pm ] |
Do I have the lean burn carb? I thought not.
| Author: | 1930 [ Wed Sep 25, 2013 2:58 pm ] |
Quote: Quote:
The black one I believe plugs into part of the EGR vacuum control system. The white plug is J1C-14R on the wiring diagram I posted. It is the positive feed for the oil pressure sending unit as well as the choke thermostat. |
| Author: | 1930 [ Wed Sep 25, 2013 3:01 pm ] |
Quote: Quote:
Resistor for the choke thermostat. The wire spliced into one of the field wires from the alternator feeds current to one side of that resistor and the other side of that resistor attaches to the wire that goes to the choke thermostat bolted in the exhaust manifold. Bolt the resistor to the rear bolt hole in the top of the head. |
| Author: | Reed [ Wed Sep 25, 2013 3:08 pm ] |
If those trucks came with those distributors, then you do not have the Mopar ignition "brain" on the firewall. Those distributors are both lean burn distributors and are not compatible with the old Mopar electronic ignition systems. You will need to install a completely new ignition system that will not plug in to any part of the old harness. You can salvage the old smaller two prong plug that used to plug into the distributor and reuse it. Just keep as much of the wire length as possible. I will try again and advise you to upgrade to the HEI ignition system. It is the easiest, cheapest, and best ignition you can install on your truck. Rejoice, you do not have a lean burn carburetor. |
| Author: | 1930 [ Wed Sep 25, 2013 3:09 pm ] |
I am assuming at this point I am looking for a dist that has a vacuum canister and has the single electronic pick-up? |
| Page 3 of 6 | All times are UTC-07:00 |
