Wiring in a points type dist
https://slantsix.org/forum/viewtopic.php?t=53944
Page 3 of 3
Author:  Aggressive Ted [ Mon Dec 09, 2013 6:05 pm ]
Post subject:  3 ohm Pertronix coils
What do you think please Smile
Pass.
Get a coil that is wound with the correct gauge wire for 3 ohms internal resistance from Pertronix with no built in resistors. They are a little over $30.00. There are many to choose from, oil filled, epoxy filled and HEI styles, and in chrome or black. Summit Racing, Jeg's or Amazon.com http://www.amazon.com/s/ref=nb_sb_noss/ ... ix%20coils
You want to reduce heat in a coil for higher output under demanding conditions, not increase it so it reduces output and or prematurely breaks down.
Author:  1930 [ Tue Dec 10, 2013 2:27 am ]
Post subject:  Re: 3 ohm Pertronix coils
Pass.
Ok found a few somewhat local Petronix dealers and will be calling today, hoping they have that coil you suggested in stock. Thanks again Ted
Page 3 of 3 All times are UTC-07:00
