It is currently Sun Nov 22, 2026 2:42 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page Previous 1 2 3
 Post subject: Re: fan update
PostPosted: Mon Jan 27, 2014 12:44 pm
OK, the votes are in, my SL6 really likes the belt driven fan way better than the electric fans.
This was essentially because, although the electric fan setup did a great job of cooling the engine, it did not do much of anything to keep the engine bay temperature down. It was cooking in there.
Yep. I played with efans on my Jeeps a lot. I'm back to clutch fans now because I needed to get rid of stuff that causes worries. Like if the fan fails, you are down.
The best setup I had was with a controller from
www.dccontrol.com that will run the fan at least 10% all the time. That took care of the engine bay baking. I also did hood vents.
The other problem was when the big efan kicked on I got a system voltage sag and EFI doesn't like that. Two things cured that. Big wire from the battery to the efan and keeping those runs as short as possible. A long run will cause a nasty sag. And the controller slowly ramped the fan up eliminating full draw at efan startup.
