Thermostat question.
https://slantsix.org/forum/viewtopic.php?t=54168
Page 3 of 3
Author:  Sean Mallory [ Mon Jan 27, 2014 12:44 pm ]
Post subject:  Re: fan update
OK, the votes are in, my SL6 really likes the belt driven fan way better than the electric fans.
This was essentially because, although the electric fan setup did a great job of cooling the engine, it did not do much of anything to keep the engine bay temperature down. It was cooking in there.
Yep. I played with efans on my Jeeps a lot. I'm back to clutch fans now because I needed to get rid of stuff that causes worries. Like if the fan fails, you are down.
The best setup I had was with a controller from
www.dccontrol.com that will run the fan at least 10% all the time. That took care of the engine bay baking. I also did hood vents.
The other problem was when the big efan kicked on I got a system voltage sag and EFI doesn't like that. Two things cured that. Big wire from the battery to the efan and keeping those runs as short as possible. A long run will cause a nasty sag. And the controller slowly ramped the fan up eliminating full draw at efan startup.
Page 3 of 3 All times are UTC-07:00
