| 1945 carb https://slantsix.org/forum/viewtopic.php?t=54229 |
Page 3 of 3 |
| Author: | Reed [ Tue Jan 07, 2014 2:50 pm ] |
Theoretically, it could be adjusted to have an effect on how much idle speed was added. However, this is not something you really need to be worrying about (or messing with). Just get your base idle speed, idle mixture, and timing set and be happy with it. |
| Author: | 1930 [ Wed Jan 08, 2014 2:22 am ] |
Quote: Theoretically, it could be adjusted to have an effect on how much idle speed was added. However, this is not something you really need to be worrying about (or messing with). Just get your base idle speed, idle mixture, and timing set and be happy with it.
Ok, thanks, you say theoretically though, is there any other purpose for this adjustment screw?I ask cause one guy poster said I had it incorrect and you say theoretically it may be used for what I had guessed it was used for. Ive already messed with it so eventually I will have to go back and mess with it again and Id like too be perfectly clear of what I am messin with. I never did see the small low idle adjusting screw back there initially. They have it hidden pretty well. Im sure fiddling with that isnt going to solve the issues I am having so I plan to tear it down and re-build it. I am looking forward to doing this.....I have that super six set-up hopefully being mailed today ( seller was sick on Mon. ) and I know that carb is going to need gone thru as well. Between all these carbs I have collected I think I can start doing some stand-up jobs on getting some of them re-built. |
| Author: | 1930 [ Wed Jan 08, 2014 2:26 am ] |
I have also been wondering, when the throttle shafts show signs of wear I have read that they have to be re-bushed? Is that correct? Is that something that the average guy can do, dosent sound like it, sounds like it would require some precision machine work and the correct part. Maybe there is a kit avail. Just curious, do not have any plan of getting into this but would be nice to know I could if I had too. |
| Author: | 1930 [ Wed Jan 08, 2014 2:39 am ] |
Also someone posted for me a PDF ( maybe ) file of specific info for my particular carb. They posted it on the Ramcharger forum. I had a heck of a time viewing it but finally got it printed. If anyone would like a copy just ask, I can scan and send it thru-e-mail. Dont know how to post a link to the specific article here. |
| Page 3 of 3 | All times are UTC-07:00 |
