| Guess what I got? A Hyperpak https://slantsix.org/forum/viewtopic.php?t=54474 |
Page 3 of 7 |
| Author: | Junior [ Sat Feb 01, 2014 7:03 pm ] |
there is. i didnt know for the longest time. kept getting diferent brands of 225 mounts hoping to get something like i had in there when i got the car and couldnt figure out why they were so much smaller. then one day i remembered it was a 170 car and looked it up for that motor and it turned out to be exactly what i was looking for. if you go to rock auto and look up a 1966 valiant with the 170 and find the motor mounts look at the pics and reference it to the 225 mounts. they are worlds apart. |
| Author: | Charrlie_S [ Sun Feb 02, 2014 4:20 am ] |
The rock auto catalog is wrong, as is most other catalogs. I went through this years ago. If you look the listing for a 66 Valiant with 225 is for mount numbers 2265 and 2264, and the 170 is for numbers 2303 and 2304. If you look at 1967 valiant the mount numbers are 2265 and 2264 this is correct. The mounts changed between 66 and 67. Now look up the numbers for a 66 Dart, it lists the same number for a 225 and a 170, numbers 2303 and 2304. In short the numbers 2265 and 2264 are incorrect for a 66 Valiant, they are for a 67 Valiant. The reason you had a problem, was everyone was giving you a mount for a 67 car, which will not work. The factory parts manual does not show a difference between a 170 and a 225 mount, within the same year, "A" body. |
| Author: | Junior [ Sun Feb 02, 2014 5:57 am ] |
gotcha, thank you for the clarification. i aways assumed they were just different mounts. |
| Author: | Charrlie_S [ Sun Feb 02, 2014 7:20 am ] |
Quote: gotcha, thank you for the clarification. i aways assumed they were just different mounts.
No problem. Like I said, I went through this years ago, an tore my hair out trying to get the right mounts.PS: nobody will correct their catalogs. I gave up trying. |
| Author: | emsvitil [ Sun Feb 02, 2014 12:40 pm ] |
I used 2303 & 2304 on my 64 225 Valiant When I got them, that was the number cross-referenced (I'm pretty sure at rock auto too) Now Rock Auto shows the 2264 & 2265 for a 64 225 and 2303 & 2304 for a 170 The 2304 @ 2303 did look like my original mounts. What's the difference? |
| Author: | Romeo Furio [ Sun Feb 02, 2014 1:12 pm ] |
Rick, I have only one thing to say,,,,,, I HATE YOU !! |
| Author: | Charrlie_S [ Sun Feb 02, 2014 1:45 pm ] |
Quote: Rick, I have only one thing to say,,,,,, I HATE YOU !!
Not me. I love him so much, I am going to marry him. Then I will get the manifolds in the divorce. PS: 2265 and 2264 mounts are for 67-72, in "A" bodies. Many more years in trucks. |
| Author: | Red [ Sun Feb 02, 2014 2:22 pm ] |
Those is bee-otchin'! |
| Author: | wvenable [ Sun Feb 02, 2014 4:47 pm ] |
| Post subject: | The Slant Sixth Dimension... |
Witness Mr. Rick Covalt. A regular guy who won the Hyper Pak lotto. All he wanted was to race. Little does he know he has just entered a different world. A world filled with admiration, jealousy, hatred, and man marriage proposals. A world called the slant six twilight zone. |
| Author: | emsvitil [ Sun Feb 02, 2014 4:53 pm ] |
Do those bolt bosses on the exhaust manifold line up with something on the hyperpak? |
| Author: | Rick Covalt [ Sun Feb 02, 2014 5:00 pm ] |
Yes , Bolts go through the intake into the exhaust manifolds. |
| Author: | GTS225 [ Sun Feb 02, 2014 7:24 pm ] |
Personally, I think those would look even better hangin' off the side of my open engine, in the front of my '23 T project, with the Offy 2x1 intake nestled in between the runners. Go with a true dual exhaust, but weld the pipes side-by-side, with a rib down the center, and a brass "sight bead" out near the ends to make it look like the muzzle(s) of a double-barrel shotgun. Just sayin' Roger |
| Author: | DusterIdiot [ Sun Feb 02, 2014 9:26 pm ] |
| Post subject: | Lol... |
Quote: brass "sight bead" out near the ends to make it look like the muzzle(s) of a double-barrel shotgun.
Tighten up the lash or lean out the mix on a manual transmission and the locals will think it is either a machine gun or you really are shootin' ducks. |
| Author: | Reed [ Sun Feb 02, 2014 11:01 pm ] |
If there were a porn magazine for slant sixes, these would the centerfold.
| Page 3 of 7 | All times are UTC-07:00 |
