| Engine Misfire https://slantsix.org/forum/viewtopic.php?t=55812 |
Page 3 of 3 |
| Author: | jacmifish [ Tue Nov 24, 2015 7:30 pm ] |
| Post subject: | Re: Leak around the rings |
Quote: Quote: If there is similar bypass on all cylinders, would the mean the motor wasn't broken in properly or could all my rings have gone equally bad all at once?
I find it extremely unlikely all the rings would be bad. I have accidentally installed rings upside down and that did some wacky things, so that's a possibility, maybe?Honestly I couldn't say because I had someone build the motor . I do know for sure the I have stock 225 rods with the weisco pistons which are shorter. Meaning it would be .3" or so cylinder length to the combustion volume. |
| Author: | coconuteater64 [ Tue Nov 24, 2015 10:20 pm ] |
I would look at the easy things first. Are your valves seating all the way? |
| Author: | jacmifish [ Wed Nov 25, 2015 4:55 am ] |
I put every cylinder at TDC and verified by making sure there was no pressure on the springs, then I applied pressure to the cylinder. I couldn't hear any air coming through the intake or exhaust and didn't see bubbles in the coolant. |
| Author: | coconuteater64 [ Wed Nov 25, 2015 4:36 pm ] |
If there's no air escaping from the dipstick tube either, then maybe it's time to see just how far down the hole the piston sits at TDC. |
| Page 3 of 3 | All times are UTC-08:00 |
