| Overheating https://slantsix.org/forum/viewtopic.php?t=58458 |
Page 3 of 3 |
| Author: | Oppie5150 [ Fri Oct 16, 2015 6:09 pm ] |
Evening everybody, I'm in need of help again/still I'll start with info. I have replaced, radiator,water pump, thermostat, flushed the system, adjusted valves to spec, moved fan closer to radiator, checked timing and is at 9 degrees My issue is a very strange one, I can drive car all day at 45 and temp stays at the sweet spot about a 1/4 way up the gauge, as soon as I go above 55 the temp slowly creeps up and keeps going until it starts to over heat I did notice that once I turned into the neighborhood and was doing about 20 the temp slowly came down to about 3/4 up the gauge I'm at a loss to do and I need a reliable car and this thing is killing me |
| Page 3 of 3 | All times are UTC-08:00 |
