| BBD throttle cable? https://slantsix.org/forum/viewtopic.php?t=58631 |
Page 3 of 3 |
| Author: | Rick Covalt [ Sun Feb 14, 2016 2:12 pm ] |
Quote: From the firewall to the super six cable clamp in a straight line is 9". That means the main housing should be 10-11" long
That is what the above quote was for. It might could be 12 or 13" but 20 will be too long.Rick |
| Author: | matv91 [ Sun Feb 14, 2016 2:34 pm ] |
Back in the day after cars got a little older it was common to cut that nylon tie strap. And let cable hang down in half loop . Did this myself a few times. Full loop would as it wore would bind up .By late 1980s those tie straps would have been cut or failed from engine heat and vibration. |
| Author: | Reed [ Sun Feb 14, 2016 2:35 pm ] |
I looked at a 81-83 Dodge truck and van parts manual to see if there were pictures of the throttle cables. The parts manual shows V-8 throttle cables being routed with loops, but not the slant six throttle cable, even on the BBD models. I cna tell you that right now on my 76 D100 I am running the original one barrel throttle cable with a tight loop in it to shorten it up to work with the Super Six setup. There is no way to make the cable reach the carb and still function without a loop. |
| Author: | Rick Covalt [ Sun Feb 14, 2016 3:07 pm ] |
If I do not find the correct cable I will get one off a mini van that is very long and make a nice wide loop instead of the tight one. Rick |
| Author: | Rick Covalt [ Mon Feb 15, 2016 2:18 pm ] |
That looks to be correct to me. Now where to get them? |
| Page 3 of 3 | All times are UTC-07:00 |
