| It's Bristol Baby Slant Six Shootout https://slantsix.org/forum/viewtopic.php?t=59526 |
Page 3 of 6 |
| Author: | myfirstmopar [ Mon Jun 13, 2016 12:49 pm ] |
There are other classes Super pro, pro, trophy, Sportsman, Jr dragster, motorcycle. There is a lot of good racing to watch, when we are not racing. |
| Author: | Greg Ondayko [ Mon Jun 13, 2016 1:24 pm ] |
Quote: Best way to get there from I 81 is to take exit 69 in TN turn left if your coming from the north, that is 394 stay on 394 and it leads you to the gate for the Drag Strip on the left.
Thanks for the good directions.Quote: Every car must have a neutral safety switch where the car can not start in drive. Greg |
| Author: | myfirstmopar [ Mon Jun 13, 2016 6:52 pm ] |
the reason I mention it is because they stop me from racing one weekend because I bypassed it when I started racing the duster and I had to fix it before I could go through tech. |
| Author: | Greg Ondayko [ Tue Jun 14, 2016 8:39 am ] |
Got the NSS Functioning Correctly This Morning! See you guys next weekend! Greg |
| Author: | Rick Covalt [ Sat Jun 18, 2016 7:49 am ] |
Should we bring pop up tents? I guess we can use them on the black top? If it is over 100 degrees I am out!! |
| Author: | Ron Hamby [ Sun Jun 19, 2016 2:10 am ] |
Yes to the popup tents. |
| Author: | Challenger [ Sun Jun 19, 2016 6:06 pm ] |
| Post subject: | Nss |
My Nss is not working either and I have no idea how to wire one up.the tranny has the 3 pin plug screwed in but I find no other wires to hook to it. I guess I will have to pass on Bristol until I figure this out.norm |
| Author: | Rick Covalt [ Sun Jun 19, 2016 7:08 pm ] |
Norm they aren't hard to hook up. If I can do it you can. Greg can probably rattle it off if he just did his. Rick |
| Author: | Ron Hamby [ Sun Jun 19, 2016 7:15 pm ] |
Norm here you go. The Chrysler 3 prong switch works as follows: A. Outer terminals #1 & #3 are for the backup lites, these contacts are normally openand then closed to complete the power circuit to the reverse lites. B. The center terminal #2 is for the neutral safety switch, this is grounded when thee linkage is in park or neutral. Its wire goes to the starter relay. Inside the transmission is a lever arm which pushes the switch when in the respective position. http://www.dodgecharger.com/forum/index ... 6945;image This should be what you need to get it fixed Ron |
| Author: | bmimken [ Mon Jun 20, 2016 9:44 am ] |
Just a follow up about where to park. As Jack said, behind the tower by the creek. When you come in past the gates, instead of taking a right to the pits, go straight. There is a small parking lot near the creek where we will be. I will bring a radio to listen for track announcements. On another note, I do not have my car ready for this race and would like to borrow an available car if possible! I can come and pick up/drop off with my trailer. I know it is a long shot, but had to ask! Brian |
| Author: | Ron Hamby [ Mon Jun 20, 2016 11:20 am ] |
Brian I talked to Gary. He is not coming, he is rebuilding the eng in his red valiant. He said you could use his beige valiant if you want. He said Meril may have a car as well. You might want to call him or Meril. Thanks Ron |
| Author: | Greg Ondayko [ Mon Jun 20, 2016 12:05 pm ] |
Quote: Should we bring pop up tents? I guess we can use them on the black top? If it is over 100 degrees I am out!!
You should be fine nothing over 90*..Greg |
| Author: | bmimken [ Mon Jun 20, 2016 12:41 pm ] |
Forgot to mention that where we will be parking that there are a couple of trees that "might" offer some shade! I'm bringing a small generator to power a couple of fans for relief as well. Brian |
| Author: | Rick Covalt [ Mon Jun 20, 2016 12:58 pm ] |
Quote: he is rebuilding the engine in his red valiant.
He rebuilds that almost as much as I do mine! We need some more locals to show up! Any bushes we should be kicking? There was a NC fellow & his son who were trying to get their car ready last year. Mike Andeas maybe? Anyone heard from him? I really hate to not have a big turnout for this race. The promoter has certainly done his part.Did Gary say if Meril was coming? Rodney make sneak in under cover? |
| Author: | Rick Covalt [ Mon Jun 20, 2016 1:08 pm ] |
Quote: would like to borrow an available car if possible!
My Valiant is available, what time are you coming by? Rick |
| Page 3 of 6 | All times are UTC-07:00 |
