It is currently Mon Nov 23, 2026 6:39 pm
Post new topic  Reply to topic  [ 70 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Fri Jun 20, 2003 11:30 am
I can't see your pictures either, but here are some of mine:
First, heres the crookedly drilled mounting holes for the carb adapter plate:
Next, I took some shots of the interior of the manifold:
Here I stuck the camera into the spot under the carb and took some blurry pictures of the runners:
3&4
1&2
5&6
Next I just took a couple pictures of the manifold itself. If you look close you can see all the bolt bosses and see which ones have been tapped:
Here's a shot showing the size difference between a standard one barrel intake and the gargantuan hyper-pak
:shock:
Finally, DI mentioned differences in mounting tab thickness. Here is a comparison of a stock manifold and the Clifford h-pak. The thinkness looks the same but the stock manifold has a "U" cut out of the side that the h-pak doesn't.
<img src="http://pages.moparpages.com/reed/hyperpak/tabcompare.JPG"width=400>
Hope all these pics work.... If you guys want I can post some better resolution pics.
Reed
PostPosted: Fri Jun 20, 2003 11:35 am
Oh yeah, the only casting number/part number/batch number I could find on my manifold was "2129898." I ordered mine on 4-10-03 and it was delivered in mid May. Clifford said that at that time the hyper pak was one of its best selling items so they had no plans to end production. Mine was one of a batch of 30 that were being cast.
To my untrained eye the casting looks pretty good. Smooth, no flash that I can find.
Reed
PostPosted: Fri Jun 20, 2003 12:08 pm
I still cant see the pics :(
However Reeds pics i could see, and from what i see i am not impressed at all, it looks like they cut alot of corners on casting these :roll: , i even made it so one would fit in my truck because i planned on useing one, after this discussion i'm very hesitent to order anything from clifford. :(
It looks like there quality is suffering big time, I'd still love to see the pictures of Cecils Intake, if someone could email me the pictures and info, i could post them from my moparpages account :)
I think this thread is long from being over....
Justin
PostPosted: Fri Jun 20, 2003 12:34 pm
Reed, my intake runners look like yours. I haven't checked the carb adapter fit. John's been trying to get my pics posted, maybe he can fix it. The 2129898 # appears to be the original part # for the HP that Doc must have put on. Is it Doc? I've called twice for Tammy to see about a return, she wasn't in. I don't think I want a replacement, it appears this whole batch may be bad. I'm hoping for credit. I'm really disappointed with mine. I had plans to put it on my '82 D100 the I'm going to use as a tow truck for my '68 Valiant racer.
Cecil
PostPosted: Fri Jun 20, 2003 12:44 pm
Well, I am going to keep mine and eventually run it. What the hell. I am not going to be shooting for a 1/4 mile fireball so I am not too worried about a top notch casting. Just as long s no parts fall into the motor I am happy.
Reed
PostPosted: Fri Jun 20, 2003 12:49 pm
Yes, 2129898 are 7 random numbers in a row and by some odd reason of chance, also the original Hyper-Pak intake part number.... :roll: :wink:
They have been on the repops from the start.
 Post subject: @#%@$%@#$^-Hyperpak....
PostPosted: Fri Jun 20, 2003 1:21 pm
I'll have to snap some pics tonight...I just spend 2 hours with a die grinder and my 4 1/2" hand grinder making things 'kinda-jake' to get this to fit up.... I like porting and whittling on cast iron, aluminum turns to taffy and plugs up everything you grind it with..... :x *GRRRRR*.
To get the dutra front and truncated rear manifold to fit, I had to whittle on one of the ears on Doug's casting (not bad compared to the rest of the project...to bad clifford doesn't have Doc's QA ethic...).
To get the rear to fit I cut the reinforcing wall off the choke pocket (that freed up enough room that it fit just fine on mockup...I even ground some meat out of the area to make it easier to put to lower washer/nut on...
I gasket matched the ports on the H-P and they weren't too far out of spec, I whittled on the runners a bit to get some more space for the exhaust manifolds...
Everything mocks up on the studs on the head, but....
I have to go back and gouge some more material out of the runners to get the triangular washers and the center washer into place for proper installation... :roll:
This is about the time where I'd plug the dual weber setup for ease of installation over the probable 'up and coming' Hyperpak Q&A 10 page article we'll compile from the data. :wink:
more later with more pics,
PostPosted: Fri Jun 20, 2003 1:55 pm
Hey, maybe we should all get together and submit a long complaint/constructive criticism letter to Clifford. Then start bugging Offy to market a similar long runner intake manifold...
Are those boomerang shaped runner dividers a problem? It seems like a "v" shape would help ease the flow transition.
Reed
PostPosted: Fri Jun 20, 2003 2:40 pm
Im with Reed,Im gonna keep mine and run it somehow.
Mark(slanted attitude)
PostPosted: Fri Jun 20, 2003 3:37 pm
One tip for DI or anyone else grinding on aluminum, use a little wax on the stone or cutter to keep the tool from loading-up with gummy aluminum. :idea:
PostPosted: Fri Jun 20, 2003 5:07 pm
Thanks for the advice doc, really appreciated, I have a block of paraffin floating around here somewhere for removing stubborn 'threaded' items.....now I'll use it for something else. :D
Here are some later shots whilst I figure out how to massage things into place...I'm thinking that pulling the engine/head might be better than trying to get it all on in the engine bay for sure....
Mock up of the exhaust system after touch up:
Here's my nice butcher job on the choke pocket, once this was done it freed up tons of room to fit between the runners:
It also makes getting at the lower stud easier if necessary with an extension.... :)
Here's a close up of areas that need to be ground good, along with some magic marker ideas of areasto touch up. I've got to make a deeper pocket for the center washer to fit better, right now it's into that stud about 1/16".
Similarly the other stud areas I ground out for clearance and are fine, now, but I'll have to gouge some more material out of the runners so the triangular washers will sit properly...
Keep you posted on progress as it occurs.
Hey Doc, just out of curiousity, how much 'modifying' was needed on the manifold that the 'Slant Sickness' mill uses?
 Post subject: ?
PostPosted: Fri Jun 20, 2003 6:39 pm
I've never used parafin, but WD 40 works also.
'66 Cuda 225/4spd
'66 Dart GT convertible 225/auto
'64 Dart GT 340/4spd
 Post subject: Hey Bud, how your H-pak?
PostPosted: Fri Jun 20, 2003 9:58 pm
Just curious since we got our 'paks' from the same source at the same time, any comment on the long running thread?
PostPosted: Fri Jun 20, 2003 10:34 pm
Yes, the Slant Sickness engine's H-Pak had the same issue, extra clearance needs to be ground for the washers to fit. As stated before, extra metal was put into the walls at that spot so you have "meat" to grind into. This washer surface "spot face" operation is a needed machining step that Clifford seems to be skipping. :cry:
As for the "V" shape runner wall, what is shown is OK, I was worried that the wall was cut back fron the floor and that would mess-up the fuel distribution. The thing to remember is to direct mixture down runners #2 & 5, these are the lean cylinders with the H-Pak.
One low RPM mod. I did on a few of the units I cast was to divide the plenum, basically run the wall between #3 & 4 all the way out to the end. I put a small 1/2" x 1/2" equializer passage in the divider just for pressure balance. Doing this really helped the off idle and mid range responce.
The other thing to remember with the H-Pak is that it can use less cam, the ram effect "tunes" stronger and at lower RPMs if you keep the cams overlap event short. (45-55 degrees)
PostPosted: Sat Jun 21, 2003 9:04 am
Hmmm, thanks Doc! :mrgreen: So obviously with a split plenum the carb would have to be mounted sideways. Does JB weld work on aluminum, or will I have to get some aluminum welding rods and use my arc welder?
One other thing I noticed on my H-pak, on the floor of the manifold, right below the carb, there is a big air bubble which created a small cave. :evil: It doesn't go all the way through but I am going to fill it just the same.
Reed
