| Alcohol, because no good story starts with a salad... https://slantsix.org/forum/viewtopic.php?t=63115 |
Page 3 of 3 |
| Author: | Greg Ondayko [ Tue Jan 22, 2019 5:01 pm ] |
| Post subject: | Re: Alcohol, because no good story starts with a salad... |
Ceej, What was the final weight you arrived at after cutting, before magging? Greg |
| Author: | Rick Covalt [ Sun Mar 07, 2021 2:28 pm ] |
Any chance there is an update on this crank? Balance? And any way possible you could post the pictures again? Thanks |
| Author: | Rob Simmons [ Mon Mar 08, 2021 7:19 am ] |
Quote: Well snicker-doodles.
I think this answers the question... Unless you're asking about his second attempt...
I thought that low hour crank would be the shizbit. I asked Andy to mag it before spending any actual moolah. The #6 journal had a nasty crack, pretty much clean around the back of the journal. Apparently running the big CVT in the J-D Windrower didn't go easy on that crank. It was almost at balance with my second pass with the grinder though. Note to self. Mag the crank before starting the slice and dice. Call that a trial run. CJ |
| Author: | Rick Covalt [ Mon Mar 08, 2021 9:10 am ] |
Yeah, but I wouldn't mind seeing the pictures again. |
| Author: | ceej [ Mon Mar 08, 2021 4:35 pm ] |
I don't know if Bobby saved the pics.... I haven't started in on round two. Got sucked down some different rabbit holes of late. As the weather improves, I'll start slinking around my slant six parts pile again... CJ |
| Author: | THOR [ Tue Mar 16, 2021 2:22 pm ] |
And you'll need to let me know when so I can perhaps come down for round #2. I'll take a look and see if I can find the pics. Being 3 years ago, chances are slim; but ya just never know! ~THOR~ |
| Author: | Doctor Dodge [ Wed Mar 17, 2021 1:48 am ] |
This crank was lightened by the Cox brothers, years ago... I was told it did not last long. If you really want a light SL6 crank, just find the 84 -87 cast crank and do some clean-up and re-balancing work to it. DD
| Page 3 of 3 | All times are UTC-08:00 |
