| Problem with Race transmission https://slantsix.org/forum/viewtopic.php?t=63560 |
Page 3 of 3 |
| Author: | sixinthehead [ Thu May 16, 2019 8:01 pm ] |
| Post subject: | Re: Problem with Race transmission |
Valve bodies are essentially hydraulic computers, full of basic (Basic? Just like with the silicon variety, one little glitch and it all crashes Kudos to you for sticking with it and finding out Why instead of throwing it away. That is when this hobby becomes a true learning experience instead of just a way to fill our time and garages. Also, major respect to Larry and Mark at Transgo - well done, gentlemen |
| Author: | Charrlie_S [ Fri May 17, 2019 3:07 am ] |
Was it the same issue with both valve bodies? |
| Author: | Dart270 [ Fri May 17, 2019 3:44 am ] |
That is amazing, Rick. Great work. Wanna build a transmission for me?? Lou |
| Author: | Old6rodder [ Fri May 17, 2019 9:35 am ] |
Curiosity question. Was the washer OD reasonably close to the piston OD? In that the washer isn't centered on the piston (as the nubbin was), and if it were too small, it could impart an angled loading when impacted. This'd result in offset wear and eventual jamming. Edit: Stupidity answer. Notice the photo, Dick. |
| Author: | Rick Covalt [ Fri May 17, 2019 9:37 am ] |
Quote: Was it the same issue with both valve bodies?
No, the reason the known good one did not work was because the Stage 3 kit blocks off the governor pressure port in the transmission case. So that one could not work because of that plug no allowing the correct pressure to get back to the valve body.Lou, Not this week! |
| Author: | Rick Covalt [ Fri May 17, 2019 9:40 am ] |
Quote: Was the washer OD reasonably close to the piston OD?
I use one slightly smaller than the OD of the plug. That way it sat flat on the plug and was too large to get behind that little nub no matter how it moved.
| Author: | Old6rodder [ Fri May 17, 2019 7:51 pm ] |
Thank you. I finally got smart enough to actually look at the picture as well. Another curiosity question. How far does that piston actually move in use? I'm putting a 904 into Cassi, and know very little of slush pumps. Time to start learning. |
| Author: | Rick Covalt [ Sat May 18, 2019 3:59 am ] |
Don't quote me but I think about 3/8" |
| Page 3 of 3 | All times are UTC-07:00 |
