| Oy vey... https://slantsix.org/forum/viewtopic.php?t=6504 |
Page 3 of 3 |
| Author: | Pierre [ Wed Aug 13, 2003 3:46 pm ] |
I wouldn't want to use a pressure washer, that is a bit too strong. Could easily eat through gaskets and if you have a weak or dry seal on the firewall, well, say hello mushy carpet. |
| Author: | shiftless [ Thu Aug 14, 2003 8:24 am ] |
Quote: I wouldn't want to use a pressure washer, that is a bit too strong. Could easily eat through gaskets and if you have a weak or dry seal on the firewall, well, say hello mushy carpet.
Nah, it's not really a problem. Just be careful not to spray anything sensitive (gaskets, seals, electronics) and you'll do fine. My Dart has a total of about 15 years worth of sitting under an old tree, not to mention the long service life before that (200,000+) miles, so you can imagine the dirt and grime that was coating *everything*. About two hours with the pressure washer, and the car is absolutely clean inside and out. |
| Page 3 of 3 | All times are UTC-07:00 |
