Head Flow Infomation Wanted
https://slantsix.org/forum/viewtopic.php?t=67075
Page 3 of 5
Author:  hyper_pak [ Sat Feb 18, 2023 2:26 pm ]
Post subject:  Re: Head Flow Infomation Wanted
True, true.
He said most of his customers buy cheap heads from summit.
Then the spend another chunk putting better parts in them.
And of course porting and flowing.
I have been charting numbers that I have stumbled on.
It will be interesting to see if the trend on my head matches what I have found.
Funny thing, this head porter lives 5 minutes from my house.
And he has a big shop in the back yard, does all his work there.
Author:  volaredon [ Sat Feb 18, 2023 2:49 pm ]
I found my head flow info and (tried to) PM it to Rick a few hours ago. I would like to know what a stock "447" peanut head is good for.
My results were done on John's flow bench at 10", and was either cyl 3 or 4.
I have a thread here buried a few pages back in the "engine" section here, about my build//, skip the "war and peace" and go to the next to last post in the thread and my results are there. That's with the SI oversize valves after I made all the iron dust. I had that head shaved 70-thou and got the chambers to 49-50cc's. My first attempt at porting a head that I hope " counted" as prior to that is played with a couple of heads deemed scrap, due to having cracks in them. Those weren't /6 heads though. And I never had either of those flowed either. I know I was in pins and needles as the " band sawed head" seemed to be resurrected and posted right around the time I did the head whose results were shown in that engine rebuild thread.
Author:  hyper_pak [ Sat Feb 18, 2023 5:47 pm ]
https://www.slantsix.org/forum/viewtopi ... 60#p502160
Author:  volaredon [ Sun Feb 19, 2023 2:32 am ]
https://www.slantsix.org/forum/viewtopic.php?f=19&t=64775&p=502160#p502160
Thanks for highlighting that to bring it back up, wish I knew how. I've recently had a few people asking me for that flow info. I also wish I knew where that head started at, when it was as cast from the factory
Author:  hyper_pak [ Sun Feb 19, 2023 6:29 am ]
No problem.
I found a set of numbers from DT also searching for flow numbers.
I used a formula to convert your 10 to 28 inH2O also and put that in my matrix.
Just seeing what trends are across all the data is interesting.
I have that old head that had a compression problem still here.
I might put the 1.88 or 1.81 (don't remember) intake and 1.5 exhaust valves back in number 3 or 4.
I will take it to the porter when I pick up my other head and see what it flows.
If he doesn't charge me too much....
He told me the other day, I don't need any more work.
He was doing me a favor in his spare time.
Author:  hyper_pak [ Sun Feb 19, 2023 12:00 pm ]
Ixnay on the second head to the porter.
He called me a minute ago about the bottom row of intake exhaust studs.
Said he was 40 minutes in and still had not flowed any air.
He said if it was a SB chevy he could have done 2 sets of heads by now.
I am thinking this is the first and last of flow work by him.
Author:  hyper_pak [ Sun Feb 19, 2023 12:27 pm ]
Ixnay on head number 1.
He does not have a bore adapter small enough for my small chambers.
He has 4.0 and up and it over laps with head bolts and adjacent chamber.
Crap, I was looking forward to the data.
No good deed goes un-punished.
Whatever that means.
Author:  slantzilla [ Sun Feb 19, 2023 2:04 pm ]
This is easy. Just drive up to John's with your heads, and I'll meet you down there with your 198 crank. :lol: :lol: :lol: :lol: :lol:
Author:  hyper_pak [ Sun Feb 19, 2023 4:07 pm ]
Easy?!?
You are a nut case!
John has everything in storage now anyway.
Author:  slantzilla [ Mon Feb 20, 2023 10:59 am ]
It would be easy for me. :mrgreen:
Author:  Rick Covalt [ Mon Feb 20, 2023 1:50 pm ]
Nut Case? For sure!! All of us are! :D :D
Author:  volaredon [ Mon Feb 20, 2023 2:04 pm ]
Easy?!?
You are a nut case!
Hey it was easy for me too.
And while I don't have a head that needs flowed/ evaluated right now (my own excluded, nevermind) I hope to run into him at the Indy swap coming up ..
Author:  kesteb [ Sun Feb 26, 2023 5:42 pm ]
So which era of cylinder heads are these numbers coming from? There is a least 4 different castings done over the years and I have a head from each era.
1) I have a 1963 head with the first generation of the chamber design. The ports neatly match the gasket and the runners have a nice flow to the valves. This may be a fluke, or the myth that yellow engines are better then red engines is true.
2) I have a version from 1974, but it is currently setting on top of the engine of our Duster. So I can't say how well it was casted.
3) I have a couple of heads from the 1976 - 1979 era. The runners need to be gasket matched and there is a definite difference in the port runners from the '63 head.
4) I have a head from 1980 and beyond. Once again they need to be gasket matched and the runners are designed differently from the others.
There must be a reason for the port runner changes. Is one era better then another?
Author:  Rick Covalt [ Sun Feb 26, 2023 5:51 pm ]
I think my head is the "169" head and that is what Mike asked me to send for porting if I had one.
Author:  hyper_pak [ Sun Feb 26, 2023 6:13 pm ]
169 is a drool tube head, 67 to 74, with the chamber wall stood up more vertical than the earlier head.
On the spark plug side.
That chamber shape is better, I agree with Mike.
Page 3 of 5 All times are UTC-07:00
