| Wiseco Big Bore pistons ANOTHER RUN!! https://slantsix.org/forum/viewtopic.php?t=68441 |
Page 3 of 7 |
| Author: | Dart270 [ Tue Dec 09, 2025 9:00 am ] |
| Post subject: | Re: Wiseco Big Bore pistons ANOTHER RUN!! |
Depends on compression ratio and level of HP as to which gasket. Can talk... Lou |
| Author: | wvenable [ Tue Dec 09, 2025 1:12 pm ] |
Thanks Lou! |
| Author: | Will [ Tue Dec 09, 2025 4:13 pm ] |
OK Thank you Will |
| Author: | Rob Simmons [ Thu Dec 11, 2025 1:26 pm ] |
Some piston info that our Wiseco rep provided. .084” oversize 405g piston weight .104” oversize he does not have the weight Rings are 1.0mm gas nitride, 1.2mm cast iron phosphate coated, 2.8mm oil stainless steel Waiting on clarification on the pin size, minimum order, etc... |
| Author: | Rick Covalt [ Thu Dec 11, 2025 4:48 pm ] |
That is nice it comes with the rings! I'm in. |
| Author: | wvenable [ Sat Dec 13, 2025 7:11 am ] |
I am also in for at least one set. We will see.... |
| Author: | Rick Covalt [ Mon Dec 22, 2025 8:10 am ] |
Heard anymore from them? |
| Author: | Rob Simmons [ Fri Dec 26, 2025 8:01 am ] |
Marshall hasn’t responded. He has always been very responsive, so he may be out of the office for the holidays. I will reach out again when I get back next week. |
| Author: | Rick Covalt [ Fri Dec 26, 2025 12:19 pm ] |
Thank you Rob! |
| Author: | terrylittlejohn [ Fri Mar 13, 2026 12:48 pm ] |
i know the canadian dollar sucks but what will the cost for a set! |
| Author: | Rob Simmons [ Sun Mar 15, 2026 10:54 am ] |
Sorry to have dropped off here for awhile. I haven’t heard from Marshall since he passed on the information from Wiseco. I will ask him for a POC at Wiseco I can deal with directly. Marshall is a rod guy, not a piston guy. My understanding is that I will need to set up another group buy, but I will clarify and report back. |
| Author: | wvenable [ Thu Mar 19, 2026 7:33 am ] |
Thanks Mater! |
| Author: | drgonzo [ Tue Apr 07, 2026 6:28 pm ] |
Watching this. |
| Page 3 of 7 | All times are UTC-07:00 |
