| Off-Kilter Racing (Lemons style) https://slantsix.org/forum/viewtopic.php?t=63114 |
Page 22 of 42 |
| Author: | Charrlie_S [ Mon Mar 29, 2021 12:35 pm ] |
| Post subject: | Re: Off-Kilter Racing (Lemons style) |
rob, What year engine (late or early crank), and what trans, (late or early) cable or linkage type shifter? |
| Author: | Rob Simmons [ Tue Mar 30, 2021 3:34 am ] |
The engine/trans in it is a later 225/904. We put a Hurst Promatic cable shifter in it. |
| Author: | Charrlie_S [ Tue Mar 30, 2021 4:10 am ] |
Ok.thanks. Saw what happened to EVR at NOLA. Figured I would look and see what I have for spare parts. Such as trns, converter, flexplate, etc. Probably wouldn't bring them down, unless you think I should, but I'm close enough do do a quick parts run if necessary. |
| Author: | Rob Simmons [ Tue Mar 30, 2021 7:22 am ] |
That's awesome Charlie! I am considering throwing a spare engine/trans on the trailer... I have one out of an 85 D100. I saw a video of it running... engine and trans are separated and no converter, but should be decent spares if needed... |
| Author: | Charrlie_S [ Tue Mar 30, 2021 2:55 pm ] |
Just let me know what to bring. probably have enough spare parts. just trying to get organised ahead of time. I thimk you saidd it had a 7 1/4 rear. What ratio, and bolt pattern? |
| Author: | Rob Simmons [ Wed Mar 31, 2021 5:24 am ] |
3.55 Sure Grip with 5x4.5 LBP. Joe left the 2.76 tag on there to fool the judges... |
| Author: | Charrlie_S [ Wed Mar 31, 2021 11:24 am ] |
I would have concerns about a 7 1/4 on a road course. I have aa 3.91 SG I have been building. Still need to set the gear pattern. I'll see if I can get bthe time to get it done, in time for spare. That is the only BBP limited slip rear I have. Most of my rears are either SPB, open or spool. |
| Author: | SpaceFrank [ Wed Mar 31, 2021 1:14 pm ] |
We ran a 7-1/4" open diff for a couple races with no problem, but I suspect the Toadracer will be putting down faster lap times than we did back then... |
| Author: | Rob Simmons [ Wed Mar 31, 2021 2:07 pm ] |
Not at Sebring. It’s just a stock motor that’s been sitting for 8-9 years. |
| Author: | SpaceFrank [ Thu Apr 01, 2021 9:07 am ] |
Charlie, any chance you can scour your 904 collection for some V8 clutch drums before Sebring? I'm still looking for a set to build up a proper race transmission. |
| Author: | Charrlie_S [ Thu Apr 01, 2021 2:04 pm ] |
Quote: Charlie, any chance you can scour your 904 collection for some V8 clutch drums before Sebring? I'm still looking for a set to build up a proper race transmission.
I'll try, in the next couple of days Wht trns are you runnin?, Approx year
| Author: | SpaceFrank [ Thu Apr 01, 2021 9:30 pm ] |
1964 cable-shift with push-buttons on the dash. Thanks! |
| Author: | Charrlie_S [ Fri Apr 02, 2021 5:27 am ] |
Quote: 1964 cable-shift with push-buttons on the dash. Thanks!
Are you still using the early small input shaft, in the trans?
| Author: | SpaceFrank [ Fri Apr 02, 2021 1:15 pm ] |
Yes, everything's original to 1964. As far as I know, the V8 drums are the only thing I'll be able to easily swap in. |
| Author: | Rob Simmons [ Fri Apr 02, 2021 4:47 pm ] |
We're getting closer on the ToadRacer logo...
| Page 22 of 42 | All times are UTC-07:00 |
