| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://slantsix.org/forum/viewtopic.php?t=60536 |
Page 24 of 39 |
| Author: | Greg Ondayko [ Thu Jun 17, 2021 3:28 pm ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
6/17/21: I got the secondary Bog sorted on the edelbrock performer 500. 2 solutions available for this problem in my research... 1. Modify / remove the small supply tube on the secondary venturi.. some models of carter / edelbrock do not have this tube on the secondary venturis.. mine did. I wanted to avoid this mod as its not easily reversible. 2. Drill the counterweight in the secondary air door. I did this and it's spot on. Can be reversed by filling the hole with leas/ nits/ bolts or welding. The AVS and thermoquads have infintetly adjustable secondary doors with no drilling. Bog is gone....ready for road trip and dragstrip blasts. Greg |
| Author: | Dart270 [ Fri Jun 18, 2021 3:58 am ] |
Super! See you very soon... Lou |
| Author: | Greg Ondayko [ Fri Jun 25, 2021 9:52 am ] |
| Post subject: | 6/25/21 |
6/25/21: After coming home from the trip last week I wanted to Investigate the timing Curve. As I just got the engine fired and running say 3 or so weeks ago, I wanted to fiddle with Valve lash, Carb tuning and the like, which i did. After a few weeks of driving and fiddling with those settings I turned my attention to the timing. I was limited by the Stock slant 6 distributors' mechanical adjustment from ma MoPar, and with no proper parts to convert to a claw style hold down from a newer lean burn or 1980's up Slant 6 Distributor I had to do some grinding and clearancing / slotting on the stock hold down plate. Before My Trip last week I was limited to 10° initial advance on the Distributor the limit was caused by the adjustment plate hitting the block as well as the arced slots - the hold down bolt(s) was hitting the end of the arc on the adjustment plate. I modded that and now was able to put a seemingly ridiculous amount of initial advance into the curve. I decided on 14° initial and 32° Total. I also experimented with the Ported advance instead of the non ported vacuum on the carb. I was running the full vacuum advance signal to the distributor before and that caused a bog / flat spot as the vacuum went away with more throttle angle. .... So I tried the ported vacuum signal to the advance can and it likes that better. Now it sure feels better below 2000 RPM. I might try another lighter advance spring in the mechanism sometime. I found that I can run the car on 87 octane under heavy load with no pinging at all. But it does diesel at times upon shutdown. Greg |
| Author: | DadTruck [ Sun Jun 27, 2021 7:38 pm ] |
Fantastic Photos Greg, thanks for posting. I had read that the Nelson Ledges track has new owners and they plan to bring the track back to its historic prominence. Nice to see a race track coming back. |
| Author: | Greg Ondayko [ Mon Jun 28, 2021 7:44 am ] |
Thanks John! I am glad you enjoyed some of the documentation. Yes NLRC has new owners and should be an up and coming track from the days of your youth waiting to be rejuvenated ! It will be fun to see what happens! Greg |
| Author: | Dart270 [ Mon Jul 19, 2021 6:13 am ] |
Looks like great fun, Greg. Wish I could join - maybe next summer... Lou |
| Author: | Greg Ondayko [ Mon Jul 19, 2021 6:38 am ] |
Quote: Looks like great fun, Greg. Wish I could join - maybe next summer...
Sure. No Problem... I still wanna get the 2 green 64's out on track / Grid side x side....Lou Life has it's priorities.. and AutoX is not always at the top of the list. Greg |
| Author: | emsvitil [ Mon Jul 19, 2021 7:04 pm ] |
How do you make sure the scales are level? Or do you it head-in, then head-out and do some math? |
| Author: | Greg Ondayko [ Tue Jul 20, 2021 2:26 am ] |
Quote: How do you make sure the scales are level?
Lay 2x4s across them.. put a level on top of that piece of wood, then adjust under each scale with thin plywood / floor tiles etc. to get the pads level.Or do you it head-in, then head-out and do some math? Greg That s how I do it |
| Author: | Dart270 [ Tue Jul 20, 2021 4:45 am ] |
Ditto for me! Lou |
| Author: | Charrlie_S [ Tue Jul 20, 2021 7:29 am ] |
Do you mean to tell me, these high dollar electronic scales don't have automatic level compensation? |
| Author: | Greg Ondayko [ Tue Jul 20, 2021 10:27 am ] |
Quote: Do you mean to tell me, these high dollar electronic scales don't have automatic level compensation?
Prolly not. I am not sure if they have that feature.. Greg |
| Page 24 of 39 | All times are UTC-07:00 |
