Slant Six Forum https://slantsix.org/forum/ |
1972 Dodge Colt https://slantsix.org/forum/viewtopic.php?t=63924 |
Page 28 of 72 |
Author: | Rick Covalt [ Mon Sep 26, 2022 11:54 am ] |
Post subject: | Re: 1972 Dodge Colt |
Stan I found my problem with my 40mm not working in my car. I will send you my final settings later this evening. They sure do look and run good! |
Author: | hyper_pak [ Mon Sep 26, 2022 6:55 pm ] |
Thanks Rick! I spent the better part of my day trying to get all the manifold/head bolts tight. It was MUCH easier with the 4 barrel, I can't get a wrench on a couple of the studs! Man I wish I could get a message to Jack Clifford! |
Author: | Greg Ondayko [ Tue Sep 27, 2022 4:02 am ] |
Quote: Thanks Rick!
I spent the better part of my day trying to get all the manifold/head bolts tight. It was MUCH easier with the 4 barrel, I can't get a wrench on a couple of the studs! Man I wish I could get a message to Jack Clifford! I bet you can in the afterlife.. for now just make some custom 1/2" box and open end wrenches with your welder and grinder. You're a flexible mechanic too right Stan? Working on Skookum Slant manifolds allows you to do mechanics' yoga poses as you reach to get the #5 and #4 Bolts tight on the bottom. |
Author: | slantzilla [ Tue Sep 27, 2022 7:49 am ] |
A 1/4" ratchet, assorted extensions, and flex sockets do wonders. |
Author: | Greg Ondayko [ Tue Sep 27, 2022 8:28 am ] |
Quote: A 1/4" ratchet, assorted extensions, and flex sockets do wonders.
Yeah that too. You're giving away all your speed secrets Dennis! |
Author: | slantzilla [ Tue Sep 27, 2022 8:56 am ] |
Author: | Rick Covalt [ Tue Sep 27, 2022 3:26 pm ] |
I am actually amazed at how easy my long tube Cliffords & Red Line are to install. I would much rather remove and install them than any stock manifolds I have ever done. Jack got those headers right! My Red line manifold comes out from the head further than your Clifford does too. |
Author: | hyper_pak [ Tue Sep 27, 2022 6:05 pm ] |
Trust me I can install a slant intake. The Clifford was designed by satan. |
Author: | Rob Simmons [ Wed Sep 28, 2022 5:26 am ] |
Quote: The Clifford was designed by satan.
Author: | hyper_pak [ Wed Sep 28, 2022 6:49 am ] |
It's not funny Rob! |
Author: | slantzilla [ Wed Sep 28, 2022 7:35 am ] |
That's what you get for being all fancy schmancy Stan. Clifford only ever made 2 good things, headers and the 4 barrel intake. |
Author: | Greg Ondayko [ Wed Sep 28, 2022 8:44 am ] |
You'll get it no worries. You are slant Racing ... Will is nowhere to be found. |
Author: | Rick Covalt [ Wed Sep 28, 2022 8:50 am ] |
Quote: if not for my good friend Will, I might not be on the track yet.
You could persuade him to come race with us at Motor Mile! I still have a set of his headers hanging on the wall.
Author: | Dart270 [ Wed Sep 28, 2022 9:53 am ] |
FYI, the Clifford Weber intake has shorter runners, but substantially larger runner Xsection (L and W dimensions) that the Redline. Lou |
Page 28 of 72 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
