| Buzzin' Half Duzzin' sold https://slantsix.org/forum/viewtopic.php?t=61414 |
Page 29 of 52 |
| Author: | slantzilla [ Thu Aug 15, 2019 3:37 pm ] |
| Post subject: | Re: Buzzin' Half Duzzin' sold |
Yeah, kind of a spur of the moment thing. Makes no matter to me, I'm not chasing any records. |
| Author: | slantzilla [ Sun Aug 25, 2019 3:10 pm ] |
Here's how close I came to disaster in Iowa. I saw oil drips on the trailer after I loaded the car yesterday. Mike saw that it was coming from around the oil pump area. I checked the gauge fitting this morning and the pipe finished cracking off.
| Author: | Rick Covalt [ Sun Aug 25, 2019 4:26 pm ] |
A low oil pressure switch is your friend!! |
| Author: | sixinthehead [ Sun Aug 25, 2019 4:38 pm ] |
That could have been much worse I wonder how much vibration is a factor with a sender and elbow hanging off the end of a pipe like that? Just trying to see the root cause so I can learn from it. |
| Author: | slantzilla [ Sun Aug 25, 2019 7:03 pm ] |
Rick, it never lost pressure. If it had broken off it would have been spraying oil in front of the right slick. Six, amazingly, on the way to Iowa I was thinking it's about time to replace the fittings and copper line with a braided hose like I have on my 340 car. |
| Author: | sixinthehead [ Sun Aug 25, 2019 8:06 pm ] |
I'm going to remember that picture the next time I'm tempted to build a plumbing tree |
| Author: | slantzilla [ Sat Sep 07, 2019 10:36 am ] |
Got my fittings and braided hose. Grand total was $48 and that included 2 hoses since I'm not sure on length. Will get them in tomorrow. Also need to check the rear end. Something seems not quite right. Maybe I should get my 4.86 together and get it in. |
| Author: | slantzilla [ Thu Dec 12, 2019 4:20 pm ] |
Valiant goes to Teig Chassis Saturday for front end upgrades. We're going to work on it not flopping the wheels all the way in when backing up, and a little better alignment. Probably pull the Clifford headers out to get them coated too. |
| Author: | Rob Simmons [ Fri Dec 13, 2019 1:58 pm ] |
Cool winter upgrades. |
| Author: | slantzilla [ Wed Dec 25, 2019 9:20 am ] |
Spent some time with Patrick yesterday working on the steering. We are putting the rack and tie rods in that came with that POS AJE kit I had for the old Duster. Patrick is also redesigning the mounts. He didn't like the old ones even though the rack had stayed in place for over 20 years. |
| Author: | Greg Ondayko [ Wed Dec 25, 2019 12:46 pm ] |
Does the aje rack fit the oe k frame or does it only fit a tublar frame? Merry christmas Zilla! Greg |
| Author: | slantzilla [ Wed Dec 25, 2019 2:57 pm ] |
Merry Christmas to you too Greg! The AJE was supposed to be a "bolt in" tube K-frame rack and pinion conversion. Unfortunately it was an ill designed piece of junk. |
| Author: | Greg Ondayko [ Wed Dec 25, 2019 4:33 pm ] |
Okay, so I made my own semiublar K frame, maybe I can just buy the rack and adapt it to what I have. Is the rack / Pinion junk or just the k frame or both? Greg |
| Author: | slantzilla [ Wed Dec 25, 2019 6:33 pm ] |
R&P is fine, just the standard Pinto/Mustang II piece. The issue was the geometry of the setup was horrible. |
| Author: | Greg Ondayko [ Wed Dec 25, 2019 6:36 pm ] |
Okay cool. I never got to look much under that blue 68.. i didnt know it had a rack. Cheers... I need to get to a midwest slant meet n greet sometime.. Greg |
| Page 29 of 52 | All times are UTC-07:00 |
