| 66 Valiant Drag project "Charlie's Angel" (Kris) https://slantsix.org/forum/viewtopic.php?t=11218 |
Page 4 of 13 |
| Author: | Charrlie_S [ Tue May 15, 2007 6:44 pm ] |
Pulled the radiator, and installed a NOS damper. Fired the motor back up, and brought the revs up in gear, with the brakes applied. Ran through the gears, and could feel the shifts in all gears. I guess it is ok, just couldn't feel the shift with a 3,000 converter and no load. Corrected a few small leaks, and did a little wireing. Lowered it from the jack stands and backed it out of the garage, under it's own power. She saw daylite for the first time in over a year. Still have a lot to do, will keep posting. |
| Author: | slantzilla [ Tue May 15, 2007 7:01 pm ] |
Cool deal Charlie! |
| Author: | Rob Simmons [ Wed May 16, 2007 1:12 am ] |
That's great Charrlie! |
| Author: | Charrlie_S [ Wed May 16, 2007 3:30 pm ] |
Trailered the car to town, today, Got a front end alignment, and put it on the scale. 2,740 with me in it. Will probably be between 50 and 100 lbs heavier, when done. Real lightweight compared to my Cuda. |
| Author: | Mister Twister [ Fri May 18, 2007 7:39 am ] |
Cool Charrlie, nice to see some lite, at the end of our tunnel vision. |
| Author: | Charrlie_S [ Fri May 18, 2007 9:01 am ] |
Quote: Trailered the car to town, today, Got a front end alignment, and put it on the scale. 2,740 with me in it. Will probably be between 50 and 100 lbs heavier, when done. Real lightweight compared to my Cuda.
Actually, decieded to try and get some more weight out. The weight break between "B" and "C" is at 2700 lbs, I was thinking it was 2800. I want to be right on the split, so I can run in either class.
| Author: | Charrlie_S [ Sat May 19, 2007 4:52 am ] |
Quote: Quote: Trailered the car to town, today, Got a front end alignment, and put it on the scale. 2,740 with me in it. Will probably be between 50 and 100 lbs heavier, when done. Real lightweight compared to my Cuda.
Actually, decieded to try and get some more weight out. The weight break between "B" and "C" is at 2700 lbs, I was thinking it was 2800. I want to be right on the split, so I can run in either class. |
| Author: | Rob Simmons [ Sun May 20, 2007 1:37 am ] |
Sounds like fun Charrlie! Wish I could be there to help too. Keep us posted. |
| Author: | Charrlie_S [ Sun May 20, 2007 6:05 am ] |
Took the car up to Gainesville Raceway, last night. Worked on it till late, and did not have it quite "race ready". I live on a dirt road, and this is not a street car, so wanted to just drive it, and make sure there were no major problems. Ran the car through tech, just two minor issues, they wanted corrected, but it would not have prevented me from running. Drove it around the pits, and, did one very short "holeshot". Can't do too much in the pits, tracks "frown" on that. The engine feels pretty good. Still have a trans pan gasket leak. I am going to install a new deep pan kit, and reusable gasket, today. I am tired trying to stop the seepage. Hope to finish wireing the tach and the nitrous system, today. Then 1 more day just going over the car, to check everything. Hopefully a test and tune on Wed nite. See if it can run in the 15's on motor. |
| Author: | newpoppop [ Sun May 20, 2007 12:59 pm ] |
Charlie, you got us on the edge of our seats, this is great... keep it up... |
| Author: | Charrlie_S [ Sun May 20, 2007 9:17 pm ] |
Quote: Charlie, you got us on the edge of our seats, this is great... keep it up...
Good to know this is of interest to someone. Finally makeing good progress, after 2 years of procrasinating.Installed the Mopar Performance deep trans pan and pickup. Used the "new" style gasket. All the gauges, tail lights, dash/gauge lites are all hooked up and working. Had to install a new light switch, for the gauges lights (bad reostat). Ordered a new seat belt from Summit. I cannot use a 4 year old RCI lap belt, but a 31 year old stock belt is OK. What a stupid rule. Aftermarket belts can not be more then 2years old. |
| Author: | Rob Simmons [ Mon May 21, 2007 12:39 am ] |
Quote: Quote: Charlie, you got us on the edge of our seats, this is great... keep it up...
Good to know this is of interest to someone. Finally makeing good progress, after 2 years of procrasinating.Installed the Mopar Performance deep trans pan and pickup. Used the "new" style gasket. All the gauges, tail lights, dash/gauge lites are all hooked up and working. Had to install a new light switch, for the gauges lights (bad reostat). Ordered a new seat belt from Summit. I cannot use a 4 year old RCI lap belt, but a 31 year old stock belt is OK. What a stupid rule. Aftermarket belts can not be more then 2years old. Keep us posted. |
| Author: | slantzilla [ Mon May 21, 2007 5:42 am ] |
I'm watching too Charlie. Quote:
Welcome to the land of lawyers Charlie. Look at the bright side, you can sell the old ones to a dirt track racer. They don't have to have theirs date coded. (at least around here)
| Author: | sandy in BC [ Mon May 21, 2007 6:33 am ] |
Im listening Mr S. ............. |
| Author: | Charrlie_S [ Mon May 21, 2007 8:34 pm ] |
Couldn't believe it. Went out to the shop, and had a puddle of trans fluid under the car |
| Page 4 of 13 | All times are UTC-07:00 |
