| Ford axles in A bawdys https://slantsix.org/forum/viewtopic.php?t=22606 |
Page 4 of 6 |
| Author: | dakight [ Sat May 12, 2007 9:33 am ] |
So what are you doing about the prop valve with the rear disks? I would think that now you could turn up the rear line pressure to get better performance out of them. |
| Author: | sandy in BC [ Sat May 12, 2007 9:33 am ] |
weight of 7 1/4 axle w/ 10" drums removed from car 160 lbs weight of similarly equipped 8.8 w/discs 185 lbs |
| Author: | sandy in BC [ Sat May 12, 2007 9:38 am ] |
I will just hook it up like it was stock. The car stopped very well before with just stock 75 Dart 4 door valving. My rear brake lines are hosed from the master to the axle...so it all will get done anyway. I still need some 3" U bolts and spring plates. I still need to look at the drive shaft. |
| Author: | slantzilla [ Sat May 12, 2007 10:14 am ] |
Quote: I will just hook it up like it was stock. The car stopped very well before with just stock 75 Dart 4 door valving.
I got a very nice set of 3" U-bolts and spring plates from Dr. Diff. He is a member on Moparts, and I think he is in California.
| Author: | heckshemi [ Sat May 12, 2007 10:54 am ] |
Sandy, the explorer rear tubes are actually 3 1/4". Stock explorer u-bolts work well. The 7 1/4" shock plates can be made to fit with elongation of the holes. Can't really see it in the pic. of my 8.8, but they are 7 1/4 shock plates. http://i64.photobucket.com/albums/h194/ ... G_0122.jpg |
| Author: | sandy in BC [ Sat May 12, 2007 1:02 pm ] |
Thats good to know Frank. Too bad they cut the ubolts when I got the axle. I have the Explorer plates but the shock mounts are way off...even though Explorer and A body use the same shock. I can get cheap u bolts sets at the machine shop. |
| Author: | dakight [ Sat May 12, 2007 1:13 pm ] |
Quote: ...even though Explorer and A body use the same shock.
| Author: | sandy in BC [ Sat May 12, 2007 1:33 pm ] |
Axle centre to u joint Yoke centre is the same (at first look) on the 7 1/4 and 8.8.....meaning I can continue to use the same stock rusty Volare wagon driveshaft I hate... I wanted a stock aluminum Aerostar Van driveshaft to work. It also means you can replace a stock Valiant axle with an 8.8 and use the stock driveshaft. (at first look....) |
| Author: | DionR [ Sat May 12, 2007 3:06 pm ] |
Quote: I got a very nice set of 3" U-bolts and spring plates from Dr. Diff. He is a member on Moparts, and I think he is in California.
Polson, MT
| Author: | icaneat50eggs [ Sat May 12, 2007 10:38 pm ] |
I measured about 1" difference between the center of the axle and the center of the yoke(between the 7 1/4 and 8.8 ) |
| Author: | sandy in BC [ Sat Jun 09, 2007 7:13 am ] |
Well this week I got the 3rd set of wrong ubolts. Disappointing......Im tempted to make the last 3 1/2"set they sent me work anyway..... I did take the time to order up all the little bits I need .....should be in in about a week. brake hoses, ujoints , pads.... Unfortunately I get about 4 hours off a week right now....so little progress would be made anyway. I want my car back. ~sniff~ |
| Author: | sandy in BC [ Sat Jun 09, 2007 10:15 am ] |
stole 3 hours ......modified the ubolts to fit ,,,,,,,mounted up everything .....I have a roller for the first time in a while. Tire clearances are perfect......found a driveshaft in the slant pile that is exactly 1"shorter than my hated Volare wagon shaft....... Brakes are next..... |
| Author: | slantzilla [ Sat Jun 09, 2007 9:04 pm ] |
| Author: | Charrlie_S [ Sun Jun 10, 2007 5:26 am ] |
Quote: stole 3 hours .....
Sometimes, you just gotta do, what you gotta do |
| Author: | AnotherSix [ Tue Jun 12, 2007 1:50 pm ] |
Sandy, this looks like it is going to be a real nice setup. I have yet to find a new rear and may very well go this route. I have been looking for an 8.25 or a 7.25 Ranger rear. I've not had much time for the search lately, but this with discs looks better. I was looking for a 3.21 ratio and thinking 3.55 as the max, but our Dart is pretty much a fun car now and so the buildup criteria is a bit looser. I could live with 3.73 gears. Any thoughts about what year explorer 8.8 to look for? My wheel clearance is rather close now, do you have a total width dimension? |
| Page 4 of 6 | All times are UTC-07:00 |
