| Bracket Racing Tech Inspection https://slantsix.org/forum/viewtopic.php?t=28085 |
Page 4 of 4 |
| Author: | Charrlie_S [ Sun May 24, 2009 3:40 pm ] |
| Post subject: | Re: Reply?? |
Quote: Charlie did you ever get a reply back on this seat belt issue. Racing belts "upgrade" obviously seems to be safer than a 40 year old set of OEM belts!
Actually, NO. I had forgotten about this. I never got a reply back. At my local track (Gainesville Raceway) The tech inspector requires that my "racing" belt be within the dates range. Which mine are, for now.
Rick |
| Author: | joesnow [ Wed May 27, 2009 6:07 pm ] |
One other thing tech guys require at sometracks anyway is a driveshaft loop if you run a slick reguardless of ET. |
| Author: | Charrlie_S [ Wed Sep 22, 2010 5:28 am ] |
Updating this old thread. I never did hear back from NHRA about the seatbelt date issue. BUT: I was reading the 2010 NHRA rule book, looking for something else, and found on Pg 20.37 "general regulations", 10:5 "Driver restraint systems". "in cases where the class does not require a SFI 16.1 driver restraint system, the two year recertification does not apply". So most of us can run a "racing" belt, that is more then two years old. (basically, as long as we don't have to run a roll bar or cage) Many part time racers do not carry a rule book with them, so I listed the reference page/section of the rule book, so if a tech inspector questions an "out dated" belt you can point it out in his book. I would suggest keeping this info in the car. |
| Author: | Volare4life [ Fri Sep 24, 2010 3:39 pm ] |
your the man charrlie !!! Great info as always, -Mike |
| Page 4 of 4 | All times are UTC-07:00 |
