It is currently Sun Nov 15, 2026 5:46 pm
Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4
PostPosted: Fri Aug 25, 2017 5:22 pm
Is it possible to use a serpentine belt ribbed pulley equipped alternator on a slant by swapping out the pulley to a v-belt pulley?
Yes, as long as the alternator is physically compatible with whatever bracket you're using and the pulley you select (a) takes the right width of V-belt, and (b) winds up aligned with the belt line of the other pulleys on the same belt.
must anything else be changed besides the pulley
No.
PostPosted: Fri Aug 25, 2017 5:45 pm
Yet again, thanks, Dan. 8)
PostPosted: Fri Aug 25, 2017 6:28 pm
FYI- If anyone is shopping for JUST a V-belt pulley, the Mopar numbers for the v-belt pulley for a 1989 Diplomat are:
4094028 (2 groove, 90 amp), 4111768 (2 groove, 114 amp), 4106094 (single groove)
