| The late-model Chrysler alternator conversion thread https://slantsix.org/forum/viewtopic.php?t=28160 |
Page 4 of 4 |
| Author: | SlantSixDan [ Fri Aug 25, 2017 5:22 pm ] |
Quote: Is it possible to use a serpentine belt ribbed pulley equipped alternator on a slant by swapping out the pulley to a v-belt pulley?
Yes, as long as the alternator is physically compatible with whatever bracket you're using and the pulley you select (a) takes the right width of V-belt, and (b) winds up aligned with the belt line of the other pulleys on the same belt.Quote: must anything else be changed besides the pulley
No.
| Author: | Reed [ Fri Aug 25, 2017 5:45 pm ] |
Yet again, thanks, Dan. |
| Author: | Reed [ Fri Aug 25, 2017 6:28 pm ] |
FYI- If anyone is shopping for JUST a V-belt pulley, the Mopar numbers for the v-belt pulley for a 1989 Diplomat are: 4094028 (2 groove, 90 amp), 4111768 (2 groove, 114 amp), 4106094 (single groove) |
| Page 4 of 4 | All times are UTC-08:00 |
