| 225 Exhaust system https://slantsix.org/forum/viewtopic.php?t=30057 |
Page 4 of 4 |
| Author: | Backtobasics [ Thu Jul 24, 2008 6:18 am ] |
KC represented here. |
| Author: | zerglin87 [ Fri Jul 25, 2008 9:53 pm ] |
I thought it out and i think ill just stick with stock diameter, but just get a flowmaster 40, any thoughts on that? |
| Author: | Joshie225 [ Fri Jul 25, 2008 10:20 pm ] |
You're giving up most of the performance gain by keeping the stock pipe. The 2 1/4" pipe is where you get the performance, but you can still choke it with a bad muffler. Flowmaster is a good prescription for headache inducing resonance. I'm about to put 2 1/4" exhaust on my Valiant and it's getting a Dynomax Super Turbo just like my '66 Dart had. Nice sound, but not too loud. |
| Author: | zerglin87 [ Sat Jul 26, 2008 12:06 am ] |
Is it a "rap" sound or is it like..throaty a bit with those dynomax, i might consider buying that. How much would it cost for one? why not the ultraflo Welded? |
| Author: | Joshie225 [ Sat Jul 26, 2008 1:21 am ] |
The Super Turbo is pretty mellow. Doesn't have the rap like you usually associate with duals on a 6 cylinder, but I think the rap is as much a function of true duals as which muffler is used. The Ultraflow welded is a bit louder than the Super Turbo. It's a lot like an overgrown glasspack, even the oval ones. I had one on my 318 Satellite with a single 3" pipe and it sounded darn good. I even have a sound clip of it somewhere, but can't find it right now. |
| Author: | orgvcregal [ Sat Jul 26, 2008 1:47 am ] |
if you wont something that"s not to loud i would run 2"pipe sports muffler and standard tail pipe i had that set once and sounded quite sporty and cheap setup |
| Author: | Aggressive Ted [ Sat Jul 26, 2008 10:00 am ] |
zerglin87, Just clamp the muffler in for now and try the Thrush Welded for $29.00 and then try another. The key is running 2 1/4 pipe all the way. You get allot more power that way. |
| Author: | zerglin87 [ Sat Jul 26, 2008 2:48 pm ] |
Quote: zerglin87,
Good idea, ill see if ican have a shop do that.
| Page 4 of 4 | All times are UTC-07:00 |
