| PowerPipe-DC (True Flow Header Design) https://slantsix.org/forum/viewtopic.php?t=39043 |
Page 4 of 12 |
| Author: | Mister Twister [ Tue Mar 09, 2010 4:55 am ] |
| Author: | Mister Twister [ Tue Mar 09, 2010 5:15 am ] |
Quote: You have taken all our bashing and advise very well.PLEASE keep up the great work.I think you are doing a fantastic job.Much appreciated.Guzzi Mark
Thanks Mark what bashing he he. I'm trying to get these finished so we can move to the T3 connection. |
| Author: | Mister Twister [ Fri Mar 12, 2010 12:09 pm ] |
We will finish the test set this weekend to go to Charrlies!! |
| Author: | Joshie225 [ Fri Mar 12, 2010 12:54 pm ] |
1-5 3-6 2-4 That's the firing order. As you can see when divided into two groups cylinders 1, 2 and 3 go together as do 4, 5 and 6. No need to change the cylinder grouping, it's already optimum. |
| Author: | Mister Twister [ Fri Mar 12, 2010 1:34 pm ] |
Thanks Joshua for the quick response. My idea was 1,5,3, into one collector and 6,2,4, into the other. Letting the first header do it's thing then the other. What would that sound like? Would it go boom boom just a thought |
| Author: | Joshie225 [ Fri Mar 12, 2010 1:52 pm ] |
If you did that you'd have an exhaust pulse every 120° and then nothing for 360° in each collector. You're crowding the pulses together rather than staggering them equally. |
| Author: | Mister Twister [ Fri Mar 12, 2010 2:11 pm ] |
| Author: | Aggressive Ted [ Fri Mar 12, 2010 3:04 pm ] |
Don, I second that! I can hardly wait to see some long tube 40" primaries with a 2.5 collector like MOPAR describes in their racing manual for the SL6. When I was back at Chrysler with my wife touring the tech labs, they said 40" was actually the best for drag racing as well as on the street since it improved the low end torque so much. Something that Clifford shorties can't and don't do.......They said that the 40" headers even with a Super Six was out standing! In the cold around Chicago they just ran a plate drilled/milled out with heater fittings on each end bolted under the intake. Can you imagine a set with 1/2" thick mounting flanges 40" long with real 6" long x 2 1/2" collectors, Ceramic coated in silver? That would work sweet on my 74 Swinger...... |
| Author: | Mister Twister [ Mon Mar 15, 2010 6:10 am ] |
Now with my new design this is what it is!! The #1 cylinder connection length is 31", #2 cylinder 28 1/2" and #3 is now 29" longer than #2 after re-bending. Now the spread of connection length is only 2 1/2" http://www.stormcomm.net/mrtwister/index.html#redirect Thanks for your input on these it has helped alot! I will get some installed pics later today. We will finish the rear soon, changing them around a little also. These will be the ones I take to Charrlies and test with at the track. Talk to ya later, back to work Don. |
| Author: | Aggressive Ted [ Mon Mar 15, 2010 10:30 am ] |
Mister Twister, This is some good info. Thanks for posting! With this information these headers should produce much more even bottom end torque compared to the Clifford shorties.... and hopefully will fit around the power steering in my 74...... How thick are the header flanges? Will they be 1/2" thick like the intake manifolds? |
| Author: | Mister Twister [ Wed Mar 17, 2010 5:27 am ] |
Here is a pic of the front 1/2 Installed, passing the power steering fine. Plenty of drop for the 170. Yes the flanges are 1/2" to match the intake. The ones in this picture are not the ones being used for the sale product. With these we can remove each tube as we build without the intake removal, nice for the build. Speaking with Charlie we went with the 2 piece flanges like clifford and others. The 1/2" flanges used will look like the ones on my other project here. We have the rear done. We will call Charlie to set up time. I would like to get these to the track soon as possible!!! Thanks again for your input on the and contributing to the build Don. |
| Author: | Mister Twister [ Sun Mar 21, 2010 5:47 am ] |
Good morning all Alot more room compared to the last set. These we made out of many used flanges and tubes. The ones that will be sold, will be one tube from head to collector. Moving these bends back towards the starter a little will bring over all connection length same as the front halfs length. Every time I build a set give us another way of gaining efficiency. The rear header has plenty of block clearance in this area. What do you all think about these? Will they fit Charlies 65 Valiant? |
| Author: | Slanted Opinion [ Sun Mar 21, 2010 11:55 am ] |
Hi, When do you predict these to be available for purchase? My '68 Dart needs a new exhaust system before I can put it on the road this Spring... - Mac |
| Author: | Mister Twister [ Mon Mar 22, 2010 3:32 am ] |
Hello Slanted Opinion The headers with this style of collector has been started and should be ready for shipping a few weeks. I will keep you up to speed Don. |
| Author: | Aggressive Ted [ Mon Mar 22, 2010 6:14 am ] |
| Post subject: | Headers |
Mister Twister, What will a set cost? What gauge tubing are you using? Thanks, |
| Page 4 of 12 | All times are UTC-07:00 |
