| Factory carb heatshield pictures https://slantsix.org/forum/viewtopic.php?t=46314 |
Page 4 of 6 |
| Author: | Aggressive Ted [ Fri Sep 07, 2012 7:23 pm ] |
| Post subject: | Template |
Why an email address? I would gladly pay for the mail to ship the paper template. Do you have dimensions to check a plot for accuracy? tedschultz74@Hotmail.com |
| Author: | SlantSixDan [ Fri Sep 07, 2012 7:58 pm ] |
Quote: Quote: 2bbl version is yes.
Is that to say that there was a factory heat shield for 2bbl slant sixes? |
| Author: | Josh P [ Tue Sep 18, 2012 6:15 pm ] |
Looks like I'll be getting my hands on the factory 2-piece style heat shield, courtesy Bruce! Dan, any info you can give on the 2-piece vs the 1-piece heat shields? Is either preferred over the other? Bruce told me the heat shield is aluminium with some kind of heat insulation that is peeling off it, I wasn't away of any insulation. If I were to make one from this template from aluminium (without the heat insulation stuff) should the shield be thicker? |
| Author: | SlantSixDan [ Tue Sep 18, 2012 6:35 pm ] |
I am not aware of any 1-piece factory heat shield. All the ones I've ever seen, either in parts catalogues or on cars, have been the 2-piece variety and as far as I know (knew?) that is the only factory type. Please take photos (at least!) of the shield you receive. Me, I would make a new shield out of stiff but flexible insulating boardlike material (i.e., gasket board) about 3/32" thick, like the factory item. |
| Author: | Josh P [ Tue Sep 18, 2012 9:20 pm ] |
Interesting, Dan. The shield was described to me as aluminum with insulation board that is curling. So would you use a sheet of aluminum with some gasket board glued to the underside or just use the gasket board stuff? |
| Author: | Jeb [ Wed Sep 19, 2012 7:52 am ] |
Quote: I am not aware of any 1-piece factory heat shield. All the ones I've ever seen, either in parts catalogues or on cars, have been the 2-piece variety and as far as I know (knew?) that is the only factory type.
Dan please refer back to the photos I posted of my heat shield. It's a factory one piece item. It was made of a fiberboard material with a tin foil like coating on the bottom.
| Author: | Bruce Pine [ Wed Sep 19, 2012 9:03 am ] |
This one piece shield is the same type that I removed from my 60,000 mile '77 Aspen many years ago. I did not keep it because it was broken. |
| Author: | SlantSixDan [ Wed Sep 19, 2012 12:06 pm ] |
Hey, lookit there. Guess I didn't look closely enough (or the thread's gone on longer than that memory slot!) Thanks for the pointer. |
| Author: | Aggressive Ted [ Wed Sep 19, 2012 2:27 pm ] |
| Post subject: | Heat Shield |
Folks, Update..... I finally made a full size plot of the.pdf from Steve who converted the photo Jeb posted at the beginning of this thread. I am trying to reverse engineer the stock factory shape. After I square up the edges, I will make one using sheet aluminum and test it out. It should provide a lot more protection compared to my existing heat shield. My current heat shield works great with a stock aluminum manifold but not so good with the stock cast iron manifold......the iron is slow to warm up and just holds the heat much longer for massive heat soak during the hot weather. |
| Author: | Reed [ Wed Sep 19, 2012 2:50 pm ] |
![]() Ted- if you get a good PDF version done, I would be interested in a copy. If you actually start making these, I would also be very interested in one for a two barrel and one for a one barrel. Mostly the one barrel at this point for my brother's Duster. |
| Author: | Aggressive Ted [ Wed Sep 19, 2012 3:48 pm ] |
Reed, Will do...however the next few weeks I am very busy with work at Boeing. It may be a month or so. I need to pull the manifolds off my engine before the bad weather sets in and replace the stock steel intake gasket......it leaks like a sieve and sounds bad! I want to install the new heat shield at that time. I will make a aluminum template to share with you and install a aluminum prototype. |
| Author: | Josh P [ Wed Sep 19, 2012 3:51 pm ] |
As soon as I get the heat shield from Bruce I'll plop it on the scanner and get a nice scan of it complete with measurements. Also talking to a few machinists currently to see if I can get one of them to do a small run to us. |
| Author: | Reed [ Wed Sep 19, 2012 4:32 pm ] |
Thanks! No rush. The Duster is still sleeping in my garage. |
| Author: | MLC Duster [ Wed Sep 19, 2012 4:47 pm ] |
I'd go in for a run. |
| Author: | SlantSixDan [ Wed Sep 19, 2012 5:41 pm ] |
I know aluminum is a popular material for a heat shield like this, but I'm not sure it is the best pick. Aluminum is metal. It conducts heat. Yes, it will baffle some of the heat away, but it's still conductive and will still heat up and transmit that heat upward to the carburetor. Why not picking something that doesn't conduct heat? An insulating material? For that matter, why not really going for it with a thick heat shield made of fibre-filled phenolic, like this what's in the photos? Not this thick, because then we are having hood clearance problems. But 1/4" or 5/16" thick, I think, would be ideal and allow the use of two thin '62-'69 carb base gaskets (one above, one below), providing really excellent insulation to keep the heat from reaching the carburetor, without screwing up hood clearance or linkage geometry. And that material is fully machinable. ![]() ![]()
| Page 4 of 6 | All times are UTC-08:00 |
