It is currently Sat Nov 28, 2026 4:33 am
Post new topic  Reply to topic  [ 69 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Jan 14, 2012 3:47 pm
Joshua, no bigger on the exhaust valves?
PostPosted: Sat Jan 14, 2012 4:19 pm
I beleive the slant has a better exhaust flow than intake, so I guess a bigger intake would make a better "bang for the buck"
If you want all you can get, do both intake and exhaust, but he did say "If I were hard up for cash I would ........" :wink:
I have no idea what I am talking about.
PostPosted: Sat Jan 14, 2012 4:23 pm
It does not flow better as in higher cfm per se, but the intake to exhaust flow ratio is rather high.
PostPosted: Sat Jan 14, 2012 4:28 pm
If you're bucks down put the money where it will do the most good. Intake flow is relatively poorer than exhaust flow (flow ratio) through a slant six head. So if you need to save money I would keep the stock exhaust valves, but only if the valves and seats are in good shape.
PostPosted: Sun Feb 19, 2012 10:40 am
Car Model: 1962 Dodge Lancer GT Black/Red
The spec numbers are back from Portland Engine Rebuilders. It appears that with the previous shaving of the head and the current clean-up of the surfaces, the measured compression ratio will be in the neighborhood of 9.384:1 cold static. This may be a tad high for a pickup pulling heavy loads over mountain passes. Ted recommends ordering a custom head gasket with a thickness that will bring the ratio back into a more usable range. The question now is what is a more usable range?
Here are the specs for you number heads.
Cylinder head milled .100" before I got it. Chamber Vol. 40 cc
Deck height @ -.180" 27.3 cc
Stock head gasket 3.488 X .046 7.2 cc
Compressed Volume 74.5 cc
Bored over .030 Bore 3.430" Stroke 4.125"
Swept Volume 624.6 cc
Total Volume 699.1 cc
For Dynamic Ratio Hot - Rod Stretch .025" Not sure how much this changes the calculations.
So what I need is some help in choosing the what compression I want to end up with and what thickness of head gasket will produce that number. I went into this thinking I wanted 9 to 9.2:1 but Ted tells me that is great for a street rod carrying no load, but that a truck with low end torque goal 8.5:1 might be better.
Thanks for the help guys and thanks for making this more fun by adding your particular ingredients of thought. Ray
PostPosted: Sun Feb 19, 2012 12:06 pm
A .100" thick head gasket would get you 8.5:1. http://www.kb-silvolite.com/calc.php?action=comp
Have you chosen a camshaft?
PostPosted: Sun Feb 19, 2012 12:41 pm
Chances are you won't be using a steel shim stock gasket. How thick is a Victor or Permatorque?
Cam will also come into play on detonation. I would bolt it together and try it first. If necessary spray some water into it.
You can try different heat ranges on the plugs.
Make sure you aren't running lean with an AFR meter.
PostPosted: Sun Feb 19, 2012 6:32 pm
MotoGrey
to help me decide on where I wanted to go on compression ratio for the build on my 83 D-150 (which I want to run on regular and I plan to tow with and load up occasionally)
I calculated where the original stock engine was, what I got is
IVC 42 ABDC, then using the RB calculator
Static 7.56
Dynamic 7.42
Calculated Cranking pressure 144
before taking the motor down, I got actual cranking pressures from 130 to 150,, after disassembly found the cross hatch still on the bores, taper on the high side but in spec,, rings look good,,,actually in decent shape after 100K miles,, this is a one family truck, always had better than average maintenance..
for the build
the cam will have a IVC of 50,, using the same calculators and a calculated cylinder volume I got
Static 8.49
Dynamic 8.17
Calculated Cranking pressure 164
the static is up 11%
Dynamic is up 9%
Cranking pressure is up 12%
I have ran a couple other compression calculators, the actual numbers are a bit different, but the ratio's are about the same,,
Basically I am betting that the factory compression numbers had about a 10% safety factor built into them, concerning pressures and detonation.
I will run a cool air intake, have a little better spark control than factory, plan to do air fuel ratio and distributor optimization.. to get some of the safety factor back.
Have you re measured the piston recession with your new .030 pistons?,, the .030 Silvolites I am using have a .020 shorter compression height than the stock pistons,, so I am going to build up the short block, check recession one more time then run the calculations to get a final target cc number for the chambers.
regards
DT
 Post subject: Depends
PostPosted: Sun Feb 19, 2012 6:44 pm
Victor Reinz about .045
Fel Pro about .039-.042
PostPosted: Mon Feb 20, 2012 10:41 am
Thank you Josh for the link. Yes I have chosen a camshaft based on DadTruck's research and engineering. It is:
Intake : is the Exhaust lobe from the OC 1333
Exaust : is the Exhaust lobe from the OC 1527.
http://www.oregoncamshaft.com/Hydraulic-Cam-Specs.html
still looking to find intake closing pt @.050 plus 15 degress. not sure how to get that.
PostPosted: Mon Feb 20, 2012 6:46 pm
If you are looking at a grind, ask the cam grinder to figure-out the Intake Closing (I. C.) point
If you already have a cam, just install it & measure the actual I.C. at lash... that ends-up being close to the "@.050 + 15 degree" reading.
 Post subject: Thanks Doc.
PostPosted: Wed Feb 22, 2012 11:46 am
Ok so whaddya think in a 4000 lb pickup that wil at times carry no more than 1000 lbs. compression at 8.5:1, 9.25:1 or somewhere in between? Looking for max hiway torque and fuel mileage. thx, Ray
PostPosted: Fri Jan 11, 2013 1:34 pm
Had the built motor sitting in the garage for a number of mos. now. finally pulled the old engine last evening. Changing some tin, Do a little cleaning, paint and prep. And in goes the New Rocking slant.. thank for all the help guys.
PostPosted: Tue Jun 04, 2013 8:29 am
I got the Engine back into Trigger at last. And it runs. Had the exhaust hooked to the header at Darrels Muffler along with 02 sensor bung.
I did have to retighten the intake exhaust manigold bolts following cam breakin.
I have the timing set at 10 btdc nd with regular it did ping. with premium it is a little better. I think I will retard it a bit more.
Anyway, so on to the tuning. So far, all I have done is to set the enrichment at idle. it is idling a little faster than i would like but I can sure feel the steady power of this setup at take off.
I notice the vaccuum that is at 16 to 17 at 750 RPM. It raises to a more acceptable 20 at 1100.
More to come, but I am certainly excited to see this project finally coming together.
Ray
http://www.flickr.com/photos/72507677@N ... 925266653/
PostPosted: Tue Jun 04, 2013 12:44 pm
great looking motor,, :D
saw that you have supersized the carb, from your original post..
did you stay with the ocg 1333 and 1527 combo for the cam,, and the narrow lsa?
oh yea,, would be interesting to see what the cranking cylinder pressures are...
let me know how it goes...
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 5 guests
