It is currently Sat Nov 28, 2026 2:09 pm
Post new topic  Reply to topic  [ 58 posts ]  Go to page Previous 1 2 3 4
PostPosted: Fri Jun 10, 2005 2:49 pm
sounds like your idle woes are IAC related.
PostPosted: Mon Jun 13, 2005 7:54 am
I need to download that datalogging software. I just rolled my own in XL, but it doesn't look that nice.
I turn off my O2 sensor and tune everything first by just looking at the O2 readings when driving at different points in the VE map, or by datalogging. I did my whole 2000+ mile trip last week with no O2 feedback and got 24-25mpg @70mph. Still tweaking a little, but mostly there. I have no fast idle provision at this point, and it idles fine after I rev it softly for 10-20 sec or so.
PostPosted: Wed Sep 14, 2005 8:28 pm
Almost done... only thing left is to tighten the manifold/headers down, do the plumbing, and the wiring. Sorry pictures are big, I tried to use the width= using straight html code but it didn't seem to take.
PostPosted: Wed Sep 14, 2005 9:13 pm
Very Cool! Lotsa inovative hard work. You my hero today.
PostPosted: Sun Sep 18, 2005 2:59 pm
I've put about, oh, 250 miles or so on the setup so far. All I did tuning wise was set req_fuel , didn't work much on anything else. Need to fuss iwth the Accelerator encrichment and cold start params, but the driveability is good, excellent torque.
PostPosted: Mon Sep 19, 2005 6:36 am
Congrats, Pierre! You have some work to do with tuning, but it will pay off.
 Post subject: Doot doot, humming along
PostPosted: Thu May 04, 2006 7:32 pm
Latest updates to this mpfi business - megasquirt is now where the glove compartment was - I got tired of it sitting on the floorboard so I finally found a home for it in the dash. Pretty soon I will be getting rid of the relay board (I really don't like the type of screw connectors on it) and wiring everything directly to the board I mounted the computer on under the dash.
Also redid intake plumbing -
http://home.inreach.com/~pierre/airclea ... erside.JPG
http://home.inreach.com/~pierre/airclea ... rfront.JPG
I can now feel confident driving the car with one foot. Once I re-routed the fuel return from the pump input directly into the tank, hot idle is plenty stable now. Every now and then I plug the computer in and tweak the tuning, still needs some work to be 100% solid but tis a never ending adventure of fun ;)
PostPosted: Fri May 05, 2006 12:52 am
Nice Pierre!!!!
Cory
-'72 Valiant Sedan, Stock (For Now)
PostPosted: Thu Jun 01, 2006 12:22 am
Site Admin
... Sorry pictures are big, I tried to use the width= using straight html code but it didn't seem to take.
Pierre, the "width=" doesn't work anymore (don't know why) but a recent software update resizes your pictures automatically and allows you to click on the picture to load the larger image.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Sun Jun 04, 2006 9:22 am
Nicely done... way to persevere on a project and see it through. Did you document how you got your MP injectors/fuel rail hardware set up? Did you have the fuel rail made or did you fab it?
I have been running MS for 2 years on a '77 Ramcharger and love it. MS is the way to go. My Duster will have MS injection and spark control.
Good Job!!
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
PostPosted: Sun Jun 04, 2006 10:49 am
The fuel rail and manifold came as you see it in the pictures from clifford direct. They apparently at one time were going to sell mpfi setups and they made a limited run of mpfi manifolds and rails. Those plans fell through - he gave me the manifold with bungs already drilled for same price as a regular one, and fuel rail for an extra $20. Only thing I "manufactured" were those hold downs and adapter plate for throttle body.
Those aren't MP injectors, they are 22lb ford/denso injectors from www.fiveomotorsport.com
Other than what's in this thread I don't have anything documented.... feel free to ask me anything here.
PostPosted: Sun Jun 04, 2006 11:06 am
Wow. Truly awesome work. Thanks for sharing the ongoing reports!
PostPosted: Sun Jun 04, 2006 9:29 pm
Wow... thanks for the compliments, I thought my installation was craptacular personally....
The bundymobile is downed for a while, hole #4 had 60 psi compression, 100 less than the rest, due to jacked up exhaust valve/seat. Getting complete rebuild done, should have the engine back within 2 weeks. Should make the EFI easier to tune....
I may do little stuff in the meantime while engine is out, cleaning up engine bay, wiring, etc. We shall see. Eager to get the new mill back in!
