| timing the slant https://slantsix.org/forum/viewtopic.php?t=54159 |
Page 4 of 4 |
| Author: | 1930 [ Sat Jan 04, 2014 2:11 pm ] |
I got the air cleaner while there
| Author: | Aggressive Ted [ Sat Jan 04, 2014 3:19 pm ] |
You did good! And yes MOPAR ECU's are still available anywhere...that isn't a problem. You should always carry a spare ECU and a spare voltage regulator. Those air cleaners aren't cheap anymore either....good one! Good diagram! Congrats! |
| Author: | 1930 [ Sun Jan 05, 2014 2:14 am ] |
Quote: You did good!
Thanks very much
| Author: | DusterIdiot [ Sun Jan 05, 2014 8:23 am ] |
| Post subject: | Did? |
Quote: I also found this carb at a different yard this A.M. Removed from a 78 Volare or Aspen, not sure.
did that engine have a distributor in it? If so you might go back and check and see what number it had on the tag....if 3874876, you might be able to use it for a recurve or sell it here for some project $. |
| Author: | 1930 [ Sun Jan 05, 2014 10:05 am ] |
| Post subject: | Re: Did? |
Quote: Quote: I also found this carb at a different yard this A.M. Removed from a 78 Volare or Aspen, not sure.
| Page 4 of 4 | All times are UTC-07:00 |
