budget turboing my valiant
https://slantsix.org/forum/viewtopic.php?t=54407
Page 4 of 22
Author:  billdedman [ Thu Apr 10, 2014 3:00 am ]
Post subject:  coming soon to a strip, somewhere...
Thanks for the kind words, Junior.... I hope we're deserving of them...
We'll let you know. We also are shooting for low 13's to start out... with only 10 pounds of boost. Our junk weighs 2,670 with no driver...
Lots and lots of "if's"... lol!
We'll know, soon...
Good luck!!!
Bill. in Conway, Arkansas
Author:  Junior [ Thu Apr 10, 2014 3:48 am ]
im sure you guys will do just fine.
i always wanted to weigh my car but every time im at the track i cant remember to do it. im probably right around 3k lbs with me in it. ill be sure to make a note and put it on my dash next time im out there.
Author:  billdedman [ Thu Apr 10, 2014 9:40 am ]
Post subject:  Heavy, heavy, heavy...
It's nice to know how much weight you are lugging down the track. I used to have a '64 Valiant 2-door sedan V-100 (bare bones car) with just a radio and heater into which I had swapped a complete powertrain out of a '71 340 Dodge Demon. That Valiant of mine had no power anything, an aluminum bell housing, a 4-speed and no scatter-shield. I weighed it three different places, and it always weighed a little over 3,100 pounds with no driver. That's 450 pounds more than our /6 car, a 4-door.
Go figure...
Bill, in Conway, Arkansas
Author:  Junior [ Wed Apr 16, 2014 4:26 pm ]
mounted my air/fuel and boost gauges today. made it to the hardware store. got sorted out. just gotta put it in and make a line for my oil. should have that done tomorrow.
<img src="http://i125.photobucket.com/albums/p79/weesers1/IMG_20140416_190743_632_zps5c8eb158.jpg" border="0" alt=" photo IMG_20140416_190743_632_zps5c8eb158.jpg"/>
couple odds and ends left and it will be firing. gonna order some exhaust tonight and the carb to carb hat gasket.
Author:  Joshie225 [ Wed Apr 16, 2014 6:16 pm ]
Wow, why isn't the gauge adapter screwed into the T?
Author:  Junior [ Wed Apr 16, 2014 7:02 pm ]
wow is right. different threads.
Author:  Joshie225 [ Wed Apr 16, 2014 8:01 pm ]
Where is it not 1/8" NPT? Wait, is that an inverted flare T? I would start over with a 3/8 to 1/8 NPT bushing instead of stacking two bushings, a 1/8 nipple, 1/8 pipe T, then the tube adapter for the gauge and a 1/8 NPT to inverted flare adapter on the branch. That's 5 total pieces instead of 7 and also shorter so it's less likely to break and leave you stranded. Better yet is Aeroquip FBM2277 threaded into the pump, the gauge fitting on the branch and an AN6 to AN4 adapter and an AN4 hose to the turbo. Three pieces, light and strong.
Author:  Junior [ Thu Apr 17, 2014 5:14 pm ]
i made what i had work with what i got. its pretty sturdy.
Author:  Junior [ Thu Apr 17, 2014 5:24 pm ]
got my oil line finished. fired it up to find out why my carb was so cheap. the baseplate was warped and leaking badly. got that straightened out and flooded it soon after. before all that i ran it for a while with the carb bad. i like the turbo noises. sounds like its gonna spool pretty quick. in the short time i did run it, it got up to temperature and started steaming out of the radiator. fun fun. let it cool for a while and topped it off to watch it run out from under the water pump. one step forward 3-6 back. it is holding enough coolant to run it in the driveway but i dont wanna drive it like that so i gotta get a pump. all in all it was a pretty good day. i should be able to get some running video tomorrow w/ turbo noises if my phone picks them up.
still gotta get some exhaust on there. anyone know a good place to get some 3" flex pipe, like 10 foot of it. found it on rockauto for $27 but $120 shipping. not gonna do that.
Author:  Volare4life [ Fri Apr 18, 2014 12:57 pm ]
I would just go hunting at the local pick and pull, thats where i found my exhaust, paid less than $25 for most of it, its not done yet lol
Author:  Junior [ Fri Apr 18, 2014 1:14 pm ]
none of the u-pull its around me have anything with 3 inch exhaust.
Author:  Joshie225 [ Fri Apr 18, 2014 1:47 pm ]
Try a diesel truck shop. I'd bet that plenty of factory 3" systems get tossed in the scrap bin.
Author:  Junior [ Fri Apr 18, 2014 2:23 pm ]
ill try and find one. there arent any around here that i know of.
Author:  Junior [ Thu Apr 24, 2014 7:11 pm ]
short update. got my water pump in, also put in a thermostat. hoses are all routed. its pretty much done. runs really well so far. havent driven it on the street yet but did move it around the drive way for a minute. spools pretty fast. waiting on some electric fans. im going to use the left over pipe from my intercooler to run my exhaust. well that is all for now. when i get the fans in ill take some video.
Author:  Volare4life [ Fri Apr 25, 2014 8:51 pm ]
I would not recommend you using your aluminium intercooler piping for the turbo exhaust, it will probably melt from the heat of the turbo
Page 4 of 22 All times are UTC-07:00
