It is currently Mon Nov 23, 2026 6:39 pm
Post new topic  Reply to topic  [ 70 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sat Jun 21, 2003 10:53 pm
Divided plenum has to run the carb sideways to work.
To divide the plenum on a casted manifold, I machine a 1/4" wide slot thru the floor of the manifold, then make a cardboard template that fits in through the slot and contacts the roof and pops-up through the carb opening.
Once I have the template a cut a piece of 1/4" aluminum plate to that shape. I leave it a little short so when it is pushed thru the slot, it is recessed some.
Now find someone who can heliarc weld and weld-up the slot. You can also get some weld beads up at the carb opening to divider plate seams.
When I was casting the manifolds, a divider wall was added by simply filing a slot into the sand core and then glueing-in a small connector piece of sand for the balance window.
PostPosted: Sun Jun 22, 2003 10:20 am
Doc,would it be possible to make a divider and insert thruogh the carb opening and epoxy it with the same stuff that the v-8 guys use to epoxy turtles in their intakes?also ,Im assuming the runners are correct(inside-at carb opening)from wahat you said.
Mark
Ive got a slanted attitude and a heavy right foot.
PostPosted: Mon Jun 23, 2003 1:59 pm
:lol:
I think I got it!
Here's a pic of the mockup, now:
I ripped on all the runners pretty good, you definately have to remove lots of material to get the traingular washers, the stud nut, and a clearance for a socket to go on there....
Here's the underside pic of the exhaust:
One thing to watchout for is the center mounting hole, mine was off about 1/4" and it pulled the intake to the front of the engine enough to make things a pain and I couldn't get the intake on correctly...so I hogged that hole out so it had more room to float....
I checked the manifold holes on my intake with some adapters and gaskets that my grandfather left me from his squarebore carbed 383, and the holes are perfect for mounting a squarebore holley in either direction...
time to clean all the aluminum shavings off myself and take a load off....
more later, :wink:
PostPosted: Mon Jun 23, 2003 3:52 pm
Man, Clifford is really "hacking" these manifolds, to have the center locating hole 1/4" off location is a big problem.
Talk about a lack of good workmanship....I could get that hole "dead-on using a gasket and a hand drill. :shock:
PostPosted: Mon Jun 23, 2003 4:10 pm
Tough to put your name on something like that.
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
PostPosted: Mon Jun 23, 2003 4:53 pm
It's like running my own 3rd world machine shop here...move hole 1/4"...well, time to get out a 3/8" bit and egg the hole with the hand drill...I was almost tempted today to grind off clifford's name and etch something else on the pad.... :?
I think it'll be worth it when it's all done, it's neat looking, but I wouldn't be proud to ever recommend anything by Clifford again... :(
PostPosted: Mon Jun 23, 2003 5:14 pm
sucks. d.i.- i was going to post a pic of my (untouched) h.p. intake to show the carb holes were spot-on for my afb. seems you have the same "old" style intake as i do, unlike the manifolds drilled for clifford's carb adapters that appear to be all screwy. i expected to have to grind on it some since that's what doug had to do in that hot rod article. i have yet to mock mine up since i'm in the middle of a few other projects. i do appreciate your pics/input on this setup. it will come in handy for many of us in the future.
-james
 Post subject: Not a prob...
PostPosted: Mon Jun 23, 2003 5:48 pm
I think a lot of this will help others in the future when they go "WTF???!" trying to put it all together, right now I have a fair bit of time on layoff, so I can fool around for a while and take care of some curiosity that will help with future projects/buildups....
I'll try to document as much as possible, and if anyone else takes the plunge maybe we could put together an article to help others in future, that way they don't have to plug the 'search' button for 200+ past posts and pics that might no longer be in a given web space...
PostPosted: Tue Jun 24, 2003 4:02 pm
OK....
1)Your post on low rpm tuning of the HP said overlap of 45-55 degrees...how critical is that...My current mill is only running 34 degrees of overlap, eventually I'd like to replace the comp cam 252 with something with more duration and a slight bump in lift....but...I'm stuck with my build for a little while until I build up the bank account again...
What will the effects be of the shorter stick? (pulls great with the super six, even after 70mph on a dead run down the interstate..but I can tell the BBD just 'flattens' things out after 65-70mph....)
2)i have a few 4 barrels to play with, but 3 of them a 600-650 CFM holley's. The one I'd like to use is the Holley 390 cfm list 8007 with vacuum secondaries....Am I going to have a problem getting the right signal to get the secondaries to open up properly?
3) Thanks for your help, just ironing out some concerns, before I really take the 'plunge'. Finished the mock up today, I think it'll be easier if I pull the head off my mill, apply the HP and duals out of the engine bay, then replace head gasket and drop the 'unit' back onto the block... :roll:
Thanks again.
PostPosted: Tue Jun 24, 2003 11:25 pm
The short overlap cam will work pretty good, that will move the power band a little lower in the RPM range.
I would think you can use a 600 cfm carb as long as it has a vacuum secondary. Be sure you get a good solid and long accelerator pump shot to help "fill-up" that big manifold or you may get an off idle hesitation.
Jet size, power valve and secondary spring settings may need adjusting but get it running first and then we can debug it from there, a higher rating power valve will most likley be needed. (10.5 is my guess base on the short overlap cam)
Do you have the linkage worked-out?
As for the install, I would just lean over the fender and do the manifold swap, unless the head / valves need some attention.
 Post subject: Thanks again!!!
PostPosted: Tue Jun 24, 2003 11:47 pm
I'll pull all my Holley's and look for a good canditate (I'll bug my friend who has a couple of 600 cfm'rs in his pile too).
Linkage!?!?!....We don't need no slantin' linkage!!!! :lol:
The way I've got the thing Eyeballed, I'd like to run the carb with the primaries toward the engine, it needs a small spacer for the carb actuators to clear the manifold. I did a mock up using some old squarebore 'spacers' my grandfather made while 'super tuning' his 383-4v...looked good. I think a custom throttle cable holder will need to be made, but it's looking like a Dodge minivan throttle cable will be perfect fit and finish.
I'm lucky since all my slants are manual trannies so that's about it other than the custom exhaust needed for the Duals....
Dang Doc, you're a bad influence.... :twisted: :wink:
thank you again,
PostPosted: Wed Jun 25, 2003 9:37 am
I reposted Cecil's photos. Check them out back in my original message.
John
PostPosted: Wed Jun 25, 2003 6:15 pm
Ive been considering the Comp Cams 264s for my slant/H-P combo any other suggestions are welcome and needed.also Im gonna have to run an adapter to clear my linkage and had thought about putting my divder in the adapter and extend it down into the plenum.What do you think about this? Another thing I was thinking about was heat to the bottom of the carb by using a sheetmatal box fit to the bottom of the plenum and welding a sort peice of pipe to the headers then connecting with regular ducting found on most mid 70's cars,would this provide sufficient heat? Also,again,will the h-p be as much trouble fitting with a headr as with the Dutra duals?
Thanks Mark
PostPosted: Wed Jun 25, 2003 8:01 pm
I talked to Comp Cams the other day and the 264 has 48 advertised degrees of overlap which puts it smack in the middle of Doc's 45-55 degree estimation in a previous post...
I'm gonna run a pipe from the front dual 'branch' to the bottom of the plenum , and might grind a little to make a typical exhaust pipe flange just bolt to it for carb heat....
Sounds like you're head scratching as much as me! :)
PostPosted: Wed Jun 25, 2003 11:04 pm
D.I. ,, :idea: I have as you may know a customised offy on my truck it has an extended divided plenium adding app. 4" to the runner lenght (coulden't fit a hyperpack because of the power brake booster) I've got no carb/manifold heat . During ideal carberator Ice conditions (30 to 50 degrees F.) I do have to let the engine reach 160 degrees after start up to avoid over rich plug fouling problems caused by ice forming as a result of the pressure drop that occurs by the increace of velocity of moist air. Below 30 degrees carberator ice is not a problem because the air is dry. at higher altitudes carb ice could occure at 70 degrees,The reason for carberator heat is an approximate 20+or- degree drop in temp caused by redused air pressure in the manifold. After your engine heats up most manifolds will be at least 20 degrees hotter than the outside temperature. So Its a trade off you can jump in your car and go when its 30 to 50 degrees out or have better year round performance. If some of you don't beleave me, the next time your in a light plane ask the pilot to give the engine some carberator heat and watch the RPM drop off. :( :o Bruce Johnson
78b4ramSnortbed/6
