| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://slantsix.org/forum/viewtopic.php?t=60536 |
Page 4 of 40 |
| Author: | sixinthehead [ Sun Jan 06, 2019 3:51 pm ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
We had the same issue with the LeMons 62, although I got the LCA and bar out without cutting it. I think we have different LCAs to use, so I just left it together (for now, at least). It's funny (sad?) how long it took to get all the old parts out. Maybe I'm getting rusty too... Hope you were faster than I was! Rob, when can we get a lift? On the plus side, the right side T-bar joint always seems to be well-oiled in a slant car Can't wait to see it/them going back together! |
| Author: | Greg Ondayko [ Sun Jan 06, 2019 5:42 pm ] |
Lifts are nice. Rob's garage is too short from the evidenince I have seen for a lift. Time for a little drive to PA and i can help wrench on the blue lemon:-) You can use the lift while you are here. Greg |
| Author: | sixinthehead [ Sun Jan 06, 2019 8:55 pm ] |
Rob's garage(s) are also too full for a lift I think he uses slant blocks for insulation. Your shop is positively sterile compared to mine. No wonder you do such nice work! |
| Author: | Rob Simmons [ Mon Jan 07, 2019 1:21 pm ] |
Quote: Rob's garage(s) are also too full for a lift
Hey! I resemble that remark! I think he uses slant blocks for insulation. |
| Author: | Greg Ondayko [ Mon Jan 07, 2019 2:23 pm ] |
| Post subject: | 1/7/19 no tubes for you dudes.. |
I called FirmFeelIndustustries today to order the tubular front bar for the car. Unfourtnately, they dont have the tubular bars now as their vendor is out of that material.... so I ordered a solid bar. Once it comes in then I will mock it up and place the tabs on the LCA's. Once those are welded in the Lca's will get their glamour treatment. Greg |
| Author: | DadTruck [ Sat Jan 12, 2019 7:34 pm ] |
Greg, do you plan to inspect the weld on the K frame while it is out and re weld as necessary? I have read that some of the factory weld jobs on K frames is erratic. I plan to give the K from the 68 Barracuda a going over. |
| Author: | Greg Ondayko [ Sat Jan 12, 2019 8:20 pm ] |
This one looks pretty good. Some are pretty poor and I bet they were not consistent either. Greg |
| Author: | Rob Simmons [ Sun Jan 13, 2019 7:43 am ] |
Check your ratchet straps that they aren’t on any rough edges. That’s a lot of weight to have one get cut. |
| Author: | Greg Ondayko [ Sun Jan 13, 2019 7:47 am ] |
No rough edges. Unistrut is smooth and has rolled over edges. Greg |
| Author: | Rick Covalt [ Sun Jan 13, 2019 2:33 pm ] |
That was one very confusing picture until I enlarged it! I couldnt figure out what and where stuff was going!! |
| Author: | Greg Ondayko [ Sun Jan 13, 2019 5:49 pm ] |
Yeah that picture doesn't make much sense with bad lighting and all the aprons painted black. Anyway more progress today. Got the K frame degreased, blasted, went over welds that had too much undercut, and begun to paint it. I also reinforced the strut rod plates and the mounting point for the LCA. lots of welding and grinding. LCA's are coming together too. Getting new bushings pressed in, and lower box plates installed. They are pretty light so I am okay with the weight penalty for now. I made up for it by removing the splash shields. Hope the FFI sway bar comes next week. Greg |
| Author: | Greg Ondayko [ Mon Jan 14, 2019 7:37 pm ] |
1/14/19: Got The K Frame Painted. Maybe I throw one more coat on there. ![]() Greg |
| Page 4 of 40 | All times are UTC-07:00 |
