suggestions for a 1970 slant 6
https://slantsix.org/forum/viewtopic.php?t=61378
Page 4 of 4
Author:  Charrlie_S [ Fri Mar 02, 2018 8:31 am ]
Post subject:  Re: suggestions for a 1970 slant 6
RE: RODS
I always install one rod/piston assy, torque, and rotate.That way if there is a problem, I know where it is. Might be a stupid question, but the rod caps, are with the rods they came from, correct? Also installed the correct way (notch to notch).
Author:  SlantSixDan [ Fri Mar 02, 2018 9:08 am ]
if using the OEM steel shim gasket. If using the felpro head gasket, install without using any sealer.
How come? I can't think of a reason not to use copper gasket spray on a composite head gasket.
Author:  Dart270 [ Fri Mar 02, 2018 9:27 am ]
I guess you could, but why? These things seal great in any case and you are making your life simpler later with potential cleaning issues. I used spray copper on composition gaskets a few times, but haven't done it in about 20 yrs.
Author:  Charrlie_S [ Fri Mar 02, 2018 10:29 am ]
I did years ago, but the newest felpro head gasket for the slant six, is a different type. It is slightly thinner, and more like a multi layer gasket, it has a coating, and a rubber type embosing at possible leak areas. Moreover Felpro says to install dry.
Author:  SlantSixDan [ Fri Mar 02, 2018 11:54 am ]
Ah, I haven't used the new-type Fel-Pro gasket. If they say put it on dry, then…put it on dry!
Page 4 of 4 All times are UTC-08:00
