Is this a Super Six Kickdown?
https://slantsix.org/forum/viewtopic.php?t=65952
Page 4 of 4
Author:  matv91 [ Mon May 10, 2021 7:25 am ]
Post subject:  Re: Is this a Super Six Kickdown?
Author:  matv91 [ Mon May 10, 2021 7:33 am ]
Illustrations found in group 14 fuel under throttle control auto transmission 225 2 V, see bottom of page illustration number 13 no part number . Models covered says all description lever throttle . See group 21
Author:  matv91 [ Mon May 10, 2021 9:44 am ]
Image 1977 shows part number
Author:  matv91 [ Mon May 10, 2021 10:24 am ]
Image one barrel and 318 V8 note illustration number lever 21 - 142 - 12
Author:  matv91 [ Mon May 10, 2021 10:29 am ]
Image illustration number 19 same part number including four barrels where tranny is 904
Author:  matv91 [ Mon May 10, 2021 11:01 am ]
Depending on what year catalog you're looking at car or truck, info can be in section 14 fuel or section 21 transmission
Author:  matv91 [ Mon May 10, 2021 11:09 am ]
Image note the angle of the D, straight D angle like in your picture would follow the top blue line and Rod be too short
Author:  matv91 [ Mon May 10, 2021 12:31 pm ]
https://www.slantsix.org/forum/viewtopic.php?t=9340 wrong angle or rod too short
Author:  matv91 [ Mon May 10, 2021 12:38 pm ]
More geometry problems https://www.slantsix.org/forum/viewtopi ... +d#p279798
Author:  wjajr [ Fri Jun 04, 2021 7:25 am ]
matv91
viewtopic.php?f=20&t=40433&p=279798&hilit=clocking+d#p279798
I had forgotten about those long winded posts. LOL
My car repairs still take three steps forward and two back. Just the nature of the beast, or the incompetence of the wrench turner. Hard tell'in, not know'in.
Bill
Author:  matv91 [ Thu Aug 18, 2022 9:39 am ]
Author:  volaredon [ Thu Aug 18, 2022 10:21 am ]
Anyone here have an extra super 6 linkage set-up they can spare?
Don't need carb or manifold. Just the rest
Author:  matv91 [ Thu Aug 18, 2022 10:38 am ]
Some guess work based on observations. The 82 parts book list the length of trans lever as 2.40 lenght center to center of large holes,the pivot points. Thats just about twice the arm lenght on carb at throttle shaft. Hard to measure but pivot points are close to 1.20 apart or 1 1/4 inch. Different carbs and years all pretty close to 1 1/4 inch. So it is not one to one movement ratio.
Author:  matv91 [ Thu Aug 18, 2022 11:07 am ]
In that picture the distance between the yellow points carb pivot points is shorter than between yellow and green pivot points on tranny lever.
Author:  matv91 [ Thu Aug 18, 2022 4:51 pm ]
Image Thats the BBD throttle shaft arm.Distance from center of shaft to center of hole for kick down linkage pin close to 1.20 or about half the trans lever lenght.
Page 4 of 4 All times are UTC-07:00
