| 1962 Valiant Station Wagon https://slantsix.org/forum/viewtopic.php?t=67103 |
Page 4 of 15 |
| Author: | SlantSixDan [ Sun Dec 24, 2023 9:27 am ] |
| Post subject: | Re: 1962 Valiant Station Wagon |
I'm really liking this slide show. |
| Author: | Dart270 [ Sun Dec 24, 2023 2:13 pm ] |
Yeah, Greg is awesome. I'm as lame as it gets... Lou |
| Author: | Rick Covalt [ Wed Dec 27, 2023 6:20 am ] |
Quote: what you mean about lame?
I think that means genius! Your hitch looks great Greg. |
| Author: | kesteb [ Wed Dec 27, 2023 2:35 pm ] |
So is the plate leaning against the cranks available on a lend/lease program or are you just showing how much you decked the block? |
| Author: | Greg Ondayko [ Thu Dec 28, 2023 8:42 am ] |
Quote: So is the plate leaning against the cranks available on a lend/lease program or are you just showing how much you decked the block?
Hi Kevin,That is a honing plate that I made a few years ago from a junk block. I did not deck this block hardly at all - just a clean up pass but it must have needed more than a few thousandths as the stamped ID numbers were mostly gone when I picked the block up after machining. Greg |
| Author: | SlantSixDan [ Thu Dec 28, 2023 1:10 pm ] |
Quote: fully back purged welds What's that mean?Quote: I revised the OE Tailpipe hanger - the rubber hanger / tire material was starting to give way so I figured I would save and restore it. - New Rubber How'd you do that?
| Author: | Greg Ondayko [ Thu Dec 28, 2023 8:20 pm ] |
Hi Dan, to answer your questions: Back purging or back gassing as it is sometimes referred to is the process used on stainless ( and probably other more exotic alloys too) where when welding on tubing, the front of the weld puddle is flooded in argon to shield it from atmospheric contamination, (normal AR gas flow from the TIG torch) however the back of the weld (inside the tube) will still have atmospheric contamination from the air inside the tube. This leads to a precipitation and hard sugar forming on the backside of the weld (in side the tube) making for ugly and brittle stuff on the innards of the tubing. Back purging prevents all of that from happening - better weld quality and more pretty/smoother inside the tube after the weld process is complete. I am not sure if this is a consideration or necessary on AL, it is not needed on mild steel or aluminized steel exhaust tubing, especially if using the Mig welding process. Here is a good snippet on the subject from some of the be$t in the Stainless Exhaust Business. Also a comparison: ![]() Second question: I mistyped, I typed revised, I should have typed restored or rejuvenated. Anyway, I had some other muffler hanger stuff in my magic bin of exhaust parts.. and I repurposed a bit of rubber hanger strap. It already had the holes in it, I just kept all the OE metal. I had to drill out the original rivet, as I had no large rivets to replace it with, and no tooling to set such a large rivet, so I used a bolt in place of the original rivet. Once unriveted, I cleaned the metal bits in the abrasive blast cabinet, then painted them. After that, I cut the long rubber strap to the original length of about 3". There were appropriately spaced holes pre-manufactured in the rubber strap that I reused. Thanks, Greg |
| Author: | SlantSixDan [ Fri Dec 29, 2023 9:45 am ] |
B'dannnng, that backpurged weld is pretty! One of those things that might not make a measurable difference, but gives one a warmfuzzy knowing it's there. I get it. And I'm adding exhaust hangers to the list of stuff weird old-car people refurbish, that most car owners never think about (or just throw away). Nice work! |
| Author: | Greg Ondayko [ Sun Dec 31, 2023 8:34 am ] |
Well thanks Dan, It's good to know someone else out there appreciates my mania.If those OE Hanger hardware bits were really rusty rotted and crusty, then I probably would have thrown them in the bin, but they were just about as perfect as 62 year old exhaust parts get!, so I saved them. |
| Author: | Rick Covalt [ Sun Dec 31, 2023 8:58 am ] |
That looks really good Greg! |
| Author: | SlantSixDan [ Sun Dec 31, 2023 9:28 am ] |
| Post subject: | Re: 12/31/23 |
Quote: not bad for picking up the TIG Torch maybe once every 3 years.
Ohhhhhhh, the wonderful thing about TIGgers,is TIGgers are wonderful things! Their tops are made out of rubber; Their bottoms are made out of springs! They're bouncy-pouncy-flouncey-jouncey; fun-fun-fun-fun-FUNNNNN! But the most wonderful thing about TIGgers is…uh …I wouldn't know; that's not in my skillset. |
| Page 4 of 15 | All times are UTC-07:00 |
